BT.com
Wishlist
Brother DCP 7055 Mono Laser Multifunction Printer
Delivery
Standard Due date unavailable
Compact Mono Laser All-in-One Printer
This versatile all-in-one offers high quality prints, scans and copies in one compact multifunction unit. You'll appreciate being able to print fast at up to 20 pages per minute (ppm), and your first page will come out after only 10 seconds. Sharp, crisp text and accurate reproduction of fine detail are a given too, with the DCP-7055's high print resolution for outstanding results. The high resolution flatbed scanner produces high quality color images of scanned documents straight to your PC. The single sheet multi-purpose tray can be used to print on thicker media such as envelopes whilst the standard paper tray boasts an impressive 250 sheet capacity so you'll replenish it less frequently.
The DCP-7055 has been designed with the budget conscious buyer in mind. A range of software features including N-in-1 printing where multi-page documents can be reduced to just one page and toner save mode can reduce print costs considerably. All supplies, including the drum, can be replaced individually. This saves you money as you only pay for what you've used. When the DCP-7055 is in sleep mode, it consumes just 0.9 watts of power. It is the most energy efficient laser multifunction from Brother ever and has helped it to achieve ENERGY STAR certification thanks to its outstanding energy efficiency.
Benefits
Low cost and compact makes this ideal for a small office
Save time with fast 20ppm print and copy speed
First page out time of less than 10 seconds
High resolution colour scanning plus scan to PDF feature
Separate drum and toner to help keep costs down - only replace the one that's run out
Less refilling with a 250 sheet paper capacity
Hi-Speed USB 2.0 connection
Added peace of mind with free 12-month warranty and lifetime technical support
Green and clean technology that meets Energy Star environmental standard
Brother DCP-7055 - multifunction printer ( B/W )
Printer / copier / scanner
Copier Type
Digital
Printing Technology
Laser ( monochrome )
Monthly Duty Cycle (max)
8000 impressions
Recommended Monthly Volume
250 - 1600 pages
Max Copying Speed
Up to 20 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 20 ppm
Max Printing Resolution
Up to 2400 x 600 dpi
Scanning
600 x 2400 dpi
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Media Size
76.2 x 116 mm (min) - 216 x 406.4 mm (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thin paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
PC Connection Availability
PC Connection
USB 2.0
Office Machine Features
Scan to e-mail
40.5 cm x 39.9 cm x 26.8 cm
9.8 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Copier Type
Digital
Printing Technology
Laser - monochrome
8000 impressions
250 - 1600 pages
Display
2 lines x 16 characters
PC Connection
USB 2.0
Scan to e-mail
Standard Memory
16 MB
Copying
Max Copying Speed
Up to 20 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
2 on 1, 4 on 1
Printing
Max Printing Speed
Up to 20 ppm
Image Enhancement Technology
Brother HQ1200
Scanning
Optical Resolution
600 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Colour Depth (Internal)
48 bit
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
Min Media Size
76.2 x 116 mm
Max Media Size
Other
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), B6 (125 x 176 mm)
250 sheets
1 sheet
100 sheets
Input tray - 250 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 1 sheet - 216 x 406.4 mm weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 20 ppm - B/W , Copying: up to 20 ppm - B/W
1 x USB 2.0
Operating System Support
Linux, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows XP Professional x64 Edition, MS Windows 7, Apple Mac OS X 10.6.x, Apple Mac OS X 10.4.11, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows 2000 Professional, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), Apple Mac OS X 10.5.x, MS Windows Server 2008, MS Windows Server 2008 R2
445 Watt
Power Consumption Standby
55 Watt
Power Consumption Sleep
0.9 Watt
Warm Up Time
7 sec
First Copy Out Time B/W
12 sec
Consumables Included
1 x Cartridge ( black ) - up to 700 pages - Brother TN2010 , 1 x drum - up to 12000 pages - Brother DR-2200
Limited warranty - 1 year
40.5 cm
39.9 cm
26.8 cm
9.8 kg
Shipping Width
52.7 cm
Shipping Depth
51 cm
Shipping Height
44 cm
Shipping Weight
12.9 kg
Sound Emission
30 dBA (idle) / 53 dBA (operating)
Accessories
Brother BRO DR2200 DRUM HL2240/2240D/
Quicklinx: 79P7 | In Stock
£59.91
£29.40
Scroll to top
