BT.com
Wishlist
Brother DCP-1510 A4 Mono Multifunction Laser Printer
Brother DCP-1510 A4 Mono...
£68.07
10 in stock
£68.07
Add to wishlist
Delivery
Standard 1-3 working days
The stylish DCP-1510 is a neat, all-in-one solution for the home office.
Fast and durable, it allows you to print, scan and copy effortlessly from one compact machine with always impressive results.
Quick and easy to install, this hardworking, multifunction printer has an impressive range of features, including special anti-jam technology. It prints at high speeds of up to 20ppm too so you can expect your first page in less than 10 seconds.
All in all, the DCP-1510 makes black and white printing easy – always delivering professional documents and a professional performance.
Brother DCP-1510 - multifunction printer ( B/W )
Printer / copier / scanner
Printing Technology
Laser ( monochrome )
Monthly Duty Cycle (max)
9000 pages
Recommended Monthly Volume
1800 pages
Max Copying Speed
Up to 20 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 20 ppm
Max Printing Resolution
Up to 2400 x 600 dpi
Scanning
600 x 1200 dpi
Original Size
215.9 x 300 mm (max)
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, recycled paper
Standard Media Capacity
150 sheets
Output Trays Capacity
50 sheets
PC Connection Availability
PC Connection
USB 2.0
AC 230 V ( 50/60Hz )
38.5 cm x 255 cm x 34 cm
7 kg
Microsoft Certification
Compatible with Windows 7
Printing Technology
Laser - monochrome
9000 pages
1800 pages
Display
2 lines x 16 characters
PC Connection
USB 2.0
Standard Memory
16 MB
Copying
Max Copying Speed
Up to 20 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
2 on 1, 4 on 1
Printing
Max Printing Speed
Up to 20 ppm
Printer Drivers / Emulations
Windows GDI driver
Image Enhancement Technology
Brother HQ1200
First Print Out Time B/W
10 sec
Scanning
Optical Resolution
600 x 1200 dpi
Interpolated Resolution
19200 x 19200 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Document & Media Handling
Max Original Size
215.9 x 300 mm
Original Type
Sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
105 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), Folio (216 x 330 mm)
150 sheets
50 sheets
Input tray - 150 sheets - Legal (216 x 356 mm) weight: 64 g/m² - 105 g/m² , Output tray - 50 sheets
Speed Details
Printing: up to 20 ppm ( A4 ) - B/W , Copying: up to 20 ppm - B/W
1 x USB 2.0 - 4 pin USB Type B
Operating System Support
Linux, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, Apple Mac OS X 10.7.x, Apple Mac OS X 10.8.x, Windows 8, Apple Mac OS X 10.6.8
380 Watt
Power Consumption Standby
40 Watt
Power Consumption Sleep
0.8 Watt
First Copy Out Time B/W
16 sec
Consumables Included
1 x Cartridge ( black ) - up to 700 pages - Brother TN1050 , 1 x drum - up to 10000 pages - Brother DR1050
38.5 cm
255 cm
34 cm
7 kg
Shipping Width
50.5 cm
Shipping Depth
45.8 cm
Shipping Height
43.6 cm
Shipping Weight
8.9 kg
Sound Emission
51 dBA (operating)
10 °C
32.5 °C
20 - 80% (non-condensing)
Scroll to top
