BT.com
Wishlist
Brother ADS-3000N Professional High Speed Desktop Document Scanner
Brother ADS-3000N Professional High...
£416.65
£416.65
Add to wishlist
Delivery
Standard Due date unavailable
The ImageCenter ADS-3000N High-Speed Desktop Scanner with Gigabit Ethernet and SuperSpeed USB 3.0 connectivity offers powerful features for mid- to large size workgroups that help simplify the way documents are captured, managed, processed, and delivered. Using the 50-page capacity auto document feeder, it captures single and double-sided documents in a single pass at speeds of up to 50ppm‡, making it perfect for scanning multi-page, two-sided business documents, as well as single-page documents up to 196" long, receipts, business cards, photographs, and plastic cards. Easily scan to a wide variety of destinations, including OCR, email, print, network, FTP/SFTP, USB flash memory drive and Microsoft SharePoint.
ADS-3000N
To support multi-departmental scanning, the ADS-3000N scans to Network, OCR (Optical Character Recognition) software, USB, FTP, File, Image, SharePoint® and email, so teams across the business can utilise the device no matter their function or requirements. The USB Host feature allows users to connect an external storage flash drive up to 64 GB.
Brother's ADS-3000N incorporates SuperSpeed USB 3.0 for enhanced connectivity, offering high performance and optimised power efficiency for improved usage and faster data transfer. The device is also USB 2.0 backwards compatibility.
With ISIS and TWAIN drivers, the ADS-3000N supports a range of advanced image processing functions for professional grade scanned outputs. Image processing functions prepare and clean scanned documents, improving the quality of the scanned image for storing, editing, sharing and OCR requirements. This ensures that business critical documents are easy to read and reference when archiving for disaster recovery and office digitisation.
With auto 2-sided colour scan, a 50 sheet ADF (Automatic Document Feeder) and rapid scanning at up to 50 pages per minute, the ADS-3000N is a professional departmental scanner for all small to medium business needs.
Network Scanners
Offering true network capability with no need to install software at multiple location points, Brother Network scanners allow documents to be scanned directly from the machine to multiple devices. With one simple press of a button or Touchscreen*, scans can be quickly and easily shared across teams and departments; improving workflow efficiency and increasing productivity.
*Touchsceen on ADS-2800W and ADS-3600W models only.
Programmable Keys
Using programmable buttons, scanned documents can be sent instantly to pre-selected destinations for quick and simple scanning, saving time and staff training. Routine scan jobs can be pre-configured more quickly and with fewer steps, improving workflow efficiency.
Direct scanning to favourite locations such as a departmental folders, email recipients or OCR (Optical Character Recognition) software means routine tasks can be performed quickly and simply. This limits the chance of error, reduces the need for staff training and speeds up everyday workflow.
Scan to USB Host
The scan to USB Host feature allows the connection of an external storage flash drive up to 64 GB.
Professional Paper Handling
Powerful, professional scanners, but still desktop friendly, Brother scanners can handle a range of media weights, using a wider output tray to neatly capture paper fed through the Automatic Document Feeder (ADF).
Our wide document stoppers offer expert stack performance, making scanned paper collection easy and reducing scan downtime. The trays are also angled to encounter less paper resistance so paper can glide more easily and stack smoothly to reduce paper folds. These small but precise engineering qualities are what make Brother a dedicated specialist in the scanner field.
Multifeed Detection
This system uses sound waves to identify potential misfeeds. The paper pathway is automatically suspended and the user alerted if an irregular signal is detected, reducing the risk of damaged documents and lost data.
Advanced Reverse Roller System
This advanced system manages incoming bulk paper jobs so only one sheet is processed at a time, for outstanding reliability when scanning a variety of document types and weights.
Advanced Image Processing Features
The built-in range of powerful scanning tools intuitively prepare and clean scanned files, improving the quality of the scanned image for storing, editing, sharing and OCR (Optical Character Recognition) needs.
This results in less ink wastage when documents are printed, reduces file sizes for sharing and generates clearly legible articles when reading. This means less time spent manually preparing and correcting documents and more time spent focusing on the core of your business.
Brother ADS-3000N - document scanner
Document scanner - desktop
Interface Type
USB 3.0, Gigabit LAN, USB 2.0 (Host)
Scan Element Type
Dual CIS
Additional Functions
Email, scan to USB, scan to FTP
Max Supported Document Size
A4 (210 x 297 mm)
Input Type
Grayscale / Color Depth
8-bit (256 colours) / 30-bit colour
Grayscale / Color Depth (External)
24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
50 ppm (mono) / 50 ppm (colour)
Max Document Size
216 mm x 50000 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
3000 scans per day
AC 120/230 V ( 50/60 Hz )
Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Apple MacOS X 10.9.x, Apple MacOS X 10.8.5, Apple MacOS X 10.10.x
30.6 cm x 25.8 cm x 25 cm
4.45 kg
Interface Type
A4 (210 x 297 mm)
Scanner
Input Type
Grayscale Depth
8-bit (256 colours)
Colour Depth
30-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
1200 dpi x 1200 dpi
Scan Mode
Single-pass
Automatic Duplexing
Scan Element Type
Dual CIS
Max Document Scan Speed B/W
50 ppm
Max Document Scan Speed Colour
50 ppm
Duty Cycle
3000 scans per day
Scanner Speed Details
50 ppm - black & white - A4 , 50 ppm - colour - A4 , 100 ipm - duplex - black & white - A4 , 100 ipm - duplex - colour - A4
Scanner Features
Scan to portable USB drive
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 50000 mm
Plain paper
Supported Document Size Details
ADF
Automatic
50 sheets
USB 2.0 - Type A , LAN , USB 3.0 - Type B
Internal power supply
Power Consumption Operational (Standby)
30 Watt
Power Consumption Stand by
4.1 Watt
Power Consumption Sleep
2.9 Watt
30.6 cm
25.8 cm
25 cm
4.45 kg
5 °C
35 °C
20 - 80%
Sound Emission
50 dB
Scroll to top
