BT.com
Wishlist
Brother ADS-2100E High Speed Duplex Document Scanner
Brother ADS-2100E High Speed Duplex...
£267.63
£267.63
Add to wishlist
Delivery
Standard 1-3 working days
With 24 page per minute (48 images per minute) scan speed through the 50 sheet Automatic Document Feeder (ADF), the ADS-2100e is perfect for small to medium office environments. Scan and archive documents quickly and easily with scan-to Searchable PDF and a range of bundled software.
The multipage detection feature identifies paper feed errors; helping to preserve original documents and maintain clear scanned images, whilst the easy to use touch button panel enables scanning direct to a USB storage device or computer.
Brother ADS-2100e - document scanner
Document scanner - desktop
Interface Type
USB 2.0, USB 2.0 (Host)
Additional Functions
Email, scan to file
Max Supported Document Size
215.9 x 863 mm
Input Type
Grayscale / Color Depth
8-bit (256 colours) / 30-bit colour
Grayscale / Color Depth (External)
24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
24 ppm (mono) / 24 ppm (colour)
Max Document Size
215.9 mm x 863 mm
Automatic Duplexing
Supported Document Type
Plain paper, business card, plastic card
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
AC 230V (50/60 Hz)
Linux, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.6 or later, Windows 8, Apple MacOS X 10.8.x, Apple MacOS X 10.7.5, Apple MacOS X 10.9.x
29.9 cm x 22 cm x 17.9 cm
3.3 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
Email, scan to file
215.9 x 863 mm
Scanner
Input Type
Grayscale Depth
8-bit (256 colours)
Colour Depth
30-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
1200 dpi x 1200 dpi
Scan Mode
Single-pass
Automatic Duplexing
Max Document Scan Speed B/W
24 ppm
Max Document Scan Speed Colour
24 ppm
Scanner Speed Details
24 ppm - black & white - A4 , 24 ppm - colour - A4 , 48 ipm - duplex - black & white - A4 , 48 ipm - duplex - colour - A4
Scanner Features
Scan to portable USB drive, Ultrasonic multifeed sensor
TWAIN, ISIS, WIA
Media Handling
Max Document Size
215.9 mm x 863 mm
Supported Document Size Details
ADF - up to 215.9 x 863 mm
Automatic
50 sheets
USB 2.0 , USB 2.0 (Host) - Type A
Calibration paper, carrier sheet, plastic card carrier sheet
1 x USB cable
AC 230V (50/60 Hz)
Power Consumption Operational (Standby)
18 Watt
Power Consumption Stand by
4 Watt
Power Consumption Sleep
1.5 Watt
Software Included
Drivers & Utilities
29.9 cm
22 cm
17.9 cm
3.3 kg
5 °C
35 °C
20 - 80%
Sound Emission
49 dBA
Scroll to top
