BT.com
Wishlist
Brother ADS-1100WZU1 A4 Colour Wireless Sheetfed Scanner
Brother ADS-1100WZU1 A4 Colour...
£159.03
13 in stock
£159.03
Add to wishlist
Delivery
Standard 1-3 working days
Cut your paperwork down to size and maximise your office space with the compact ADS-1100W
This clever machine will scan two sides of a document simultaneously at a highly productive 16ppm, while the automatic document feeder makes working with larger documents a breeze.
Suitable for Windows or Mac, the powerful professional software bundle enables workgroups to manage, manipulate and store data with ease, including scanning to USB drives. And, with built-in wireless connectivity, the ADS1100W seamlessly fits in with your existing wireless network and systems.
Digitising, accessing and using your documents has never been simpler.
Brother ImageCenter ADS-1100W - document scanner
Document scanner - desktop
Interface Type
USB 2.0, Wi-Fi(n)
Max Supported Document Size
215.9 x 863 mm
Input Type
Grayscale / Color Depth
8-bit (256 colours) / 30-bit colour
Grayscale / Color Depth (External)
24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
16 ppm (mono) / 16 ppm (colour)
Max Document Size
215.9 mm x 863 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
20 sheets
Duty Cycle
500 scans per day
AC 230V (50/60 Hz)
Linux, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.7.x, Windows 8, Apple MacOS X 10.6.8, Apple MacOS X 10.8.x
Microsoft Certification
Compatible with Windows 7
28.5 cm x 10.3 cm x 8.4 cm
1.5 kg
Interface Type
USB 2.0, Wi-Fi(n)
215.9 x 863 mm
Scanner
Input Type
Grayscale Depth
8-bit (256 colours)
Colour Depth
30-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
1200 dpi x 1200 dpi
Scan Mode
Single-pass
Automatic Duplexing
Max Document Scan Speed B/W
16 ppm
Max Document Scan Speed Colour
16 ppm
Duty Cycle
500 scans per day
Scanner Speed Details
16 ppm - black & white - A4 , 16 ppm - colour - A4 , 16 ppm - duplex - black & white - A4 , 16 ppm - duplex - colour - A4
Scanner Features
Scan to portable USB drive, AirStation One-Touch Secure System (AOSS)
TWAIN, ISIS, WIA
Media Handling
Max Document Size
215.9 mm x 863 mm
Plain paper
Supported Document Size Details
ADF - up to 215.9 x 863 mm
Automatic
20 sheets
USB 2.0 - Type B , USB - Type A
Internal power supply
AC 230V (50/60 Hz)
Power Consumption Operational (Standby)
14 Watt (1.5 Watt)
Software Included
Drivers & Utilities
28.5 cm
10.3 cm
8.4 cm
1.5 kg
5 °C
35 °C
20 - 80%
Scroll to top
