BT.com
Wishlist
Brother 8360P Laser Fax
Delivery
Standard 1-3 working days
The FAX-8360P is a highly efficient multi-tasker, and a robust and reliable machine for any busy office.
With a range of impressive fax and copy functions that deliver the ultimate in office efficiency, the FAX-8360P lets you transmit faxes in as little as two seconds. This flexible machine delivers high quality transmissions, even with very small print sizes.
And the 250-sheet paper capacity, optional 500-sheet capacity paper cassette and up to 500-page memory will ensure it's ready to take on any job that comes through-even if you're out of the office.
Brother FAX-8360P - fax / copier (B/W)
Fax / copier
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Max Copying Speed
Up to 14 ppm
Max Copying Resolution
Up to 300 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Original Size
216 mm width (max)
Original Type
Sheets
Document Feeder Capacity
30 sheets
Media Size
216 mm width (max) 216 mm width (max)
Media Type
Envelopes, plain paper
Standard Media Capacity
250 sheets
Output Trays Capacity
150 sheets
37.7 cm x 44.2 cm x 32.3 cm
12 kg
1 year warranty
Fax / copier
Fax Type
Plain paper
Printing Technology
Laser - monochrome
Display
2 lines x 16 characters
Standard Memory
8 MB 8 MB
Max Supported Memory
40 MB 40 MB
Copying
Max Copying Speed
Up to 14 ppm
Up to 300 x 600 dpi
Grey Scale Half-Tones
64
Max Document Enlargement
200%
Max Document Reduction
50%
Maximum Copies
99
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Max Battery Backup Time
9 hour(s)
Total Memory Capacity
Up to 500 pages
Fax Machine Features
Error Correction Mode (ECM)
One Touch Dialing
32 station(s)
Speed Dialing
200 station(s)
Telephone / Fax Switch
Broadcast Transmission
282 stations
Delayed Transmission
50 stations
Remote Fax Retrieval (Polling)
Fax forwarding, automatic redialing, answering machine interface
Document & Media Handling
Max Original Size
216 mm width
Original Type
Sheets
30 sheets
Max Media Size
Other 216 mm width
Supported Media Type
250 sheets
150 sheets
Paper cassette - 250 sheets - A4 (210 x 297 mm) , Output tray - 150 sheets - A4 (210 x 297 mm) , ADF - 30 sheets - A4 (210 x 297 mm)
940 Watt
Power Consumption Standby
70 Watt
Power Consumption Sleep
20 Watt
Warm Up Time
25 sec
First Copy Out Time B/W
17 sec
Consumables Included
1 x drum (black) - up to 20000 pages , 1 x toner (black) - up to 3000 pages
1 year warranty
Limited warranty - 1 year
37.7 cm
44.2 cm
32.3 cm
12 kg
Accessories
Brother TN-6300 Standard Toner
Quicklinx: HJL | In Stock
£68.02
Brother DR-6000 Drum
Quicklinx: HJN | In Stock
£156.61
Scroll to top
