BT.com
Wishlist
Brocade FastIron CX 648S-HPOE - Switch - L3 - Managed
Delivery
Standard Due date unavailable
The Brocade FastIron CX series of switches provides new levels of performance, scalability, and flexibility required for today's enterprise campus networks. With advanced capabilities, these switches deliver performance and intelligence to the network edge in a flexible 1U form factor that helps reduce infrastructure and administrative costs.
Utilizing built-in 16 Gbps stacking ports and Brocade IronStack technology, organizations can stack up to eight switches into a single logical switch with up to 384 ports. PoE models support the emerging Power over Ethernet Plus (PoE+) standard to deliver up to 30 watts of power to edge devices, enabling next-generation campus applications.
Brocade FastIron CX 648S-HPOE - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE) + 4 x shared SFP + 2 x XFP
Power Over Ethernet (PoE)
PoE
MAC Address Table Size
32K entries
Routing Protocol
OSPF, RIP-1, RIP-2, IGMPv2, IGMP, VRRP, OSPFv2, PIM-SM, static IP routing, PIM-DM, IGMPv3, PIM-SSM, ECMP, policy-based routing (PBR), MLDv2, MLD
Remote Management Protocol
SNMP 1, SNMP, RMON, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH-2
Routing, Layer 3 switching, Layer 2 switching, DHCP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, manageable, stackable, Weighted Round Robin (WRR) queuing, MAC address filtering, Link Fault Signaling (LFS), Metro Ring Protocol (MRP) support, sFlow, Brocade IronStack technology, PIM-SM snooping, Remote Fault Notification (RFN), Virtual Route Redundancy Protocol (VRRP) support, Virtual Switch Redundancy Protocol (VSRP) support, Foundry Discovery Protocol (FDP) support, event log, DHCP snooping, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Network Admissions Control (NAC), RADIUS support, SSH support, Jumbo Frames support, MLD snooping, Dynamic ARP Inspection (DAI), temperature sensor, PoE+
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1v, IEEE 802.3ak, ANSI/TIA-1057, IEEE 802.1ab (LLDP), IEEE 802.3at
Power Redundancy
Optional
44 cm x 44 cm x 4.4 cm
4.5 kg
Bundled Services
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE
32K entries
Max Units In A Stack
8
Routing Protocol
Encryption Algorithm
AES
Authentication Method
RADIUS, TACACS, TACACS+, Secure Shell v.2 (SSH2), Extensible Authentication Protocol (EAP)
48 x 10Base-T/100Base-TX/1000Base-T - RJ-45 - PoE , 1 x console - 9 pin D-Sub (DB-9) - management , 1 x Ethernet - RJ-45 - management , 2 x network stack device , 2 x XFP , 4 x SFP (mini-GBIC)
Installed Qty
1 (installed) / 2 (max)
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Plug and Play, FCC Class A certified, CISPR 22 Class A, EN55022, VCCI Class A ITE, WEEE, RoHS
44 cm
44 cm
4.4 cm
4.5 kg
Limited warranty - lifetime
5 - 95%
Accessories
£4.95
£3.79
£11.67
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.34
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.64
£52.82
Scroll to top
