BT.com
Wishlist
Bretford PureCharge Cart 40
£1,978.58
£1,978.58
Add to wishlist
Delivery
Standard Due date unavailable
The ready-to-go iPad charging solution. No cables or power adapters required. The PureCharge Cart 40, Cart 20, Station 20 and Station 10 are the first family of charge-only solutions that are ready to go without the need to add cables or power adapters included with your devices.
With the convenience of pre-installed Lightning cables and no setup required, the PureCharge products saves valuable time and money while freeing up cables and power adapters for use elsewhere in your deployment.
Bretford PureCharge Cart 40 HGFM2 - cart
Cart
92.2 cm x 55.4 cm x 97 cm
69.3 kg
Recommended Use
40 tablets
Outlets Qty
40
Material
Steel
Platinum powder
12 years warranty
Apple iPad Air; iPad mini; iPad mini 2; iPad with Retina display (4th generation)
92.2 cm
55.4 cm
97 cm
69.3 kg
Material
Steel
Platinum powder
AV Furniture
Cart
Recommended Use
40 tablets
Output
2.1 A
Outlets Qty
40
Limited warranty - 12 years , Limited warranty - electrical components - 3 years
Apple iPad Air , Apple iPad mini , Apple iPad mini 2 , Apple iPad with Retina display (4th generation)
Scroll to top
