BT.com
Wishlist
Bretford PureCharge Cart 20
£1,450.46
£1,450.46
Add to wishlist
Delivery
Standard Due date unavailable
The PureCharge Cart 20 is part of the first family of charge-only solutions that are ready to go without the need to add cables or power adapters included with your devices. With the convenience of pre-installed Lightning cables and no setup required, the PureCharge products saves valuable time and money while freeing up cables and power adapters for use elsewhere in your deployment.
Bretford PureCharge Cart 20 HGFN2 - cart
Cart
92.2 cm x 55.4 cm x 97 cm
69.3 kg
Recommended Use
20 tablets
Outlets Qty
20
Material
Steel
Platinum powder
12 years warranty
92.2 cm
55.4 cm
97 cm
69.3 kg
Material
Steel
Platinum powder
AV Furniture
Cart
Recommended Use
20 tablets
Output
2.1 A
Outlets Qty
20
Limited warranty - 12 years , Limited warranty - electrical components - 3 years
Scroll to top
