BT.com
Wishlist
Boompods Maxpod Portable Charger 5200mAh - Blue
Delivery
Standard Due date unavailable
With its compact and tactile design, the maxpod portable recharger is an ideal portable backup battery pod for phones, tablets and USB devices.
Charges through 2 smart charging ports and uses a large 5200mAh rechargeable Lithium-ion battery technology that will repower your phone, tablet or MP3 on the go.
Check the charge level using the handy indicator, the 4 LED lights show the charging status and stored power.
Features a power-down mode so if left on with no device connected, it will shut down automatically after 30 seconds to ensure the battery power is preserved for maximum usage.
Boompods MAXPOD - power bank - Li-Ion
Power bank
3.6 cm
Diameter
8.5 cm
Output Connector Type
USB - on cable: Micro-USB
Lithium Ion - 5200 mAh
1 year warranty
Power bank
3.6 cm
Diameter
8.5 cm
Enclosure Colour
Blue
Input Connectors
5 pin Micro-USB Type B (power only)
Input Connectors Qty
1
Output connectors
Total 2 : 4 pin USB Type A (power only)
Detachable Cable Connector Type
Micro-USB Type B
LED indicator
Lithium Ion
5200 mAh
On/off button
Micro-USB to USB cable
FCC, RoHS
Limited warranty - 1 year
Scroll to top
