BT.com
Wishlist
Blue Microphones Snowball USB Microphone - Black
Blue Microphones Snowball USB...
£75.87
More than 50 in stock
£75.87
Add to wishlist
Delivery
Standard 3-5 working days
Rebirth of the cool
Finally, a USB mic that's not only easy to use, but sounds as good on your desktop as it does in a professional recording studio. Meet the Snowball; the world's first professional USB mic. Whether you're recording a guitar at your kitchen table or a complete band in the studio, the Snowball can capture it with detail unheard of before in a USB mic.
Works with the iPad!
Snowball and Snowflake can be used to record on iPad via Apple's camera connection kit (USB-to-30-pin) or the Lightning to USB camera adapter! Using these adapters, you can get Blue's studio-quality audio on your iPad with any recording app, including GarageBand.
The Snowball is a direct plug n' play mic that connects to either a Mac or PC - no additional software is needed. With its dual capsule design and unique three-pattern switch (cardioid, cardioid with -10dB pad and omni), the Snowball can handle everything from soft vocals to the loudest garage band - and it's ideal for podcasting.
Blue Microphones Snowball - microphone
Microphone
Recommended Use
Computer
Gloss black
Microphone
External
Microphone Technology
Electret condenser
Microphone Operation Mode
Cardioid, omni-directional
2 years warranty
Microphone
460 g
Gloss black
Recommended Use
Computer
Microphone
External
Electret condenser
Wired
Frequency Response
40 - 18000 Hz
Connector Type
USB
2 years warranty
Service & Support Details
Limited warranty - parts and labour - 2 years
Scroll to top
