BT.com
Wishlist
BitFenix Prodigy M MATX Cube Case - Green
Delivery
Standard Due date unavailable
Meticulously crafted and beautifully engineered, Prodigy redefines the Mini-ITX chassis. The compact housing is suspended by handles made with BitFenix FyberFlex Composite for easy portability and maximum shock absorption. On the inside, our modular FlexCage gives you the flexibility to install up to five 3.5" hard disks or 2.5" SSDs, or remove it entirely to fit up to 240mm watercooling radiators and long graphics cards. For added flexibility, additional SSD locations are also included, and a choice of Midnight Black or Arctic White with interchangeable front facades mean Prodigy will suit your individual style. With tool-free convenience, two USB 3.0 ports, filtered intakes, and proprietary BitFenix SofTouch Surface Treatment, Prodigy is the compact case with no compromises.
BitFenix Prodigy M - tower - micro ATX
System cabinet
Tower
Vivid green
I/O Connectors
2 x USB 3.0 , 1 x audio line-out , 1 x audio line-in
Supported Motherboards
microATX, Mini-ITX
System Cabinet Features
Carrying handle, SofTouch coating, interior painting
No power supply
Specification Compliance
ATX / PS/2
25 cm x 35.9 cm x 40.4 cm
Tower
Max Mainboard Size
Micro ATX
microATX, Mini-ITX
ATX / PS/2
Vivid green
Cooling System
Top: 120 mm fan mount x 2 / intake , Bottom: 120 mm fan x 1 / 1 x 230 mm or 1 x 200 mm or 2 x 120 mm fan supported , Rear: 120 mm fan x 1 / exhaust / 1 x 120/140 mm fan supported
Expansion Bays
1 (total) / 1 (free) x front accessible - 5.25" , 2 (total) / 2 (free) x internal - 2 x 2.5"/3.5" shared , 2 (total) / 2 (free) x internal - 3.5" , 3 (total) / 3 (free) x internal - 2.5"
Expansion Slots
5
No power supply
25 cm
35.9 cm
40.4 cm
Scroll to top
