BT.com
Wishlist
BitFenix Comrade Midi-Tower Rear Fan PS2 PSU 7 x PCI USB3 HD Audio WH
Delivery
Standard Due date unavailable
Aimed squarely at builders on a budget, Comrade delivers high-end features at an incredibly competitive price point. Comrade brings a sleek, no-nonsense design that's ideal for the first-time builder. Dedicated 3.5" and 2.5" drive racks offer ample expansion possibilities, as well as room for long graphics cards up to 30cm in length. Tool-free drive locking mechanisms make installing storage a breeze, while dual dust filters enable quick and easy cleanup. A SuperSpeed USB 3.0 port has also been included to save you time during file transfers. Adorned with premium touches like a powder-coated interior and an aluminum-finish BitFenix badge, Comrade is a trusty mid-tower design and an unprecedented value.
BitFenix Comrade - mid tower - ATX
System cabinet
Mid tower
White
I/O Connectors
1 x USB 2.0 , 1 x USB 3.0 , 2 x audio
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Screwless drive bays, front dust filter, cable management holes, bottom mounted PSU holder
No power supply
Specification Compliance
ATX / PS/2
18.5 cm x 47.05 cm x 42.855 cm
Mid tower
Max Mainboard Size
ATX
ATX / PS/2
Internal Bays Qty
6
Front Accessible Bays Qty
3
White
Cooling System
Front: 120 mm fan mount x 2 , Rear: 120 mm fan x 1
Expansion Bays
3 (total) / 3 (free) x front accessible - 5.25" , 3 (total) / 3 (free) x internal - 2.5" , 3 (total) / 3 (free) x internal - 3.5"
Expansion Slots
7
1 x USB 2.0 , 1 x USB 3.0 , 2 x audio - mini-jack
No power supply
Max Supported Qty
1
18.5 cm
47.05 cm
42.855 cm
Scroll to top
