BT.com
Wishlist
Billion 7800VDOX Triple WAN, Dual Band 600, 3G, VOIP, VPN ADSL2 Router
Delivery
Standard Due date unavailable
Maximum Performance Dual-band Router
Featured with simultaneous dual-band technology, the BiPAC 7800VDOX can run both 2.4GHz and 5GHz bands at the same time, offering ultra-fast wireless speeds of up to 600Mbps and multiple SSIDs on both bands. The BiPAC 7800VDOX, by adopting this state-of-the-art technology, allows for multiple-demand applications, such as streaming HD videos and multiplayer gaming simultaneously.
With an integrated 802.11n Wireless Access Point, the router delivers up to 6 times the speed of an 802.11a/b/g network device. It supports a data rate of up to 600Mbps (2.4GHz and 5GHz) and is also compatible with 802.11a/b/g equipment. The Wireless Protected Access (WPA-PSK/WPA2-PSK) and Wireless Encryption Protocol (WEP) features enhance the level of transmission security and access control over wireless LAN. The router also supports the Wi-Fi Protected Setup (WPS) standard, allowing users to establish a secure wireless network by simply pushing a button. If your network requires wider coverage, the built-in Wireless Distribution System (WDS) repeater function allows you to expand your wireless network without the need for any external wires or cables.
Truly Cost Saving with the "Least Cost Routing" Feature
Making a VoIP call is extremely simple; you just need to connect your existing telephones to one or both phone ports. The BiPAC 7800VDOX complies with the most popularly adopted VoIP industrial standard, SIP protocol, ensuring interoperability with other SIP devices and major VoIP gateways. The Gateway feature called "Least Cost Routing" offers the choice of the most economical rates offered by different service providers. One RJ-11 FXO port is integrated to transmit inbound and outbound calls via PSTN fixed-line, so that users may still be able to make and receive phone calls via PSTN, while enjoying VoIP services at the same time. In addition, outgoing calls will be automatically redirected to PSTN when the Internet or VoIP service is not available. The router also supports a wider range of telephony features, such as call waiting, silence suppression, line echo cancellation, caller ID, etc.
3G/4G Mobility and Always-On Connectivity
With the BiPAC 7800VDOX you can connect a 3G/4G LTE USB modem to its built-in USB port, allowing you to watch movies, download music or access e-mail no matter where you may be. You can even share your Internet connection with others, when away on business, at a show, or wherever there is mobile signal but no fixed line access. The auto fail-over feature ensures maximum connectivity and minimum interruption by quickly and smoothly connecting to a 3G/4G LTE network in the event that your ADSL/fibre/cable line fails. The BiPAC 7800VDOX will then automatically reconnect to the ADSL/fibre/cable connection when it's restored, reducing connection costs. These features are perfect for office situations where a constant and uninterrupted connection is critical.
Experience Gigabit
The BiPAC 7800VDOX has four Gigabit LAN ports and the forth port can be configured as a WAN port if required. This EWAN offers another broadband connectivity option for connecting to a cable, VDSL, fibre or second ADSL modem. The BiPAC 7800VDOX again offers users convenience and optimal network performance with data rates reaching up to 1Gbps.
Secure VPN Connections
The BiPAC 7800VDOX supports comprehensive and robust IPSec VPN (Virtual Private Network) protocols for business users to establish private encrypted tunnels over the public Internet to secure data transmission between headquarters and branch offices. With a built-in DES/3DES VPN accelerator, the router enhances IPSec VPN performance significantly.
Pathway to the Future
The BiPAC 7800VDOX fully supports IPv6 (Internet Protocol Version 6), launched as the current IPv4 range is filling up, and IPv6 is gradually becoming the indispensable addressing system for savvy cloud computing users. Dual stack means the router is capable of running IPv4 and IPv6 in parallel during the transition period. With Billion IPv6 enabled devices, three major transition mechanisms such as Dual-Stack, Dual-Stack Lite, and 6RD (IPv6 rapid deployment) are supported to be adapted easily into service provider's IPv4/IPv6 network.
Wireless router
Enclosure Type
Desktop
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Communications
DSL modem
IP Telephony
Voice Codecs
G.723.1
Power adapter - external
Scroll to top
