BT.com
Wishlist
Best Value Rack Air Removal Unit 100-240V
Best Value Rack Air Removal Unit...
£1,881.86
£1,881.86
Add to wishlist
Delivery
Standard Due date unavailable
High-density equipment creates an environment where traditional air distribution methods are often not effective. Densely packed enclosures can cause IT equipment to overheat, resulting in downtime. The Rack Air Removal Unit SX captures exhaust heat, returns the warm air to the plenum and eliminates hot spots from the data center. Through automatic fan speed control based upon temperature, the fans will self-adjust for optimal performance. With a unit-mounted LCD display, users can view temperatures at the rack, monitor alarm conditions and adjust unit set points. The integrated network management card allows for remote monitoring and control of the Rack Air Removal Unit SX. This space-saving solution mounts to the back of either the Netshelter SX or VX enclosure, requiring zero U space.
APC rack fan kit
Rack fan kit
P/N: AR2144BLK, AR2145BLK, AR3100, AR3100CTO, AR3100SP1, AR3100SP2, AR3100-TU, AR3100X487, AR3107
Rack fan kit
Scroll to top
