BT.com
Wishlist
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
Best Value Pulse Plus 500W 120mm Fan ATX 12V 80Plus Bronze PSU
Delivery
Standard Due date unavailable
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
80PLUS Bronze Certified & ERP Ready
• Compatible with Intel ATX 12V v.2.3 and EPS 12V v.2.92 standards
• Single +12v rail provide more stability and safer power output
• Silent FDB 120mm fan for best overall airflow and heat dissipation
• Over voltage protection, Over power protection, Short Circuit protection, Thermal overload cut-off protection
• Safety agency approval: CE, CB
• Low noise and ripple
• This 12V ATX PC Power Supply is the best choice for your Desktop Computer
• 80+ Bronze Certified
Designed to conform to the new EuP Lot 6 laws, The Pulse PLus 500W PSU is an 80+ Bronze Certified unit that offers a minimum of 85% performance at 50% load. Ideal for system integrators, this unit features a low noise 12cm fan, a black coated chassis and sufficient cabling to support most entry to mid level system builds.
Scroll to top
