Click to visit BT.com
BT.com
Wishlist
Best Value Pulse 550W 120mm Silent Red Fan SATA PFC PSU
4.0*
Quicklinx: 8FKJWS00
Mfr#: PPS-550BR
Power Rating: 550Watt
£14.80
Pulse Power Supplies - A new brand of PSU that ensures stability and value for money. Excellent value for money doesn't mean corners have been cut - every Pulse PSU comes certified RoHS compliant and with Power Factor Control - giving you a safe and stable foundation to build systems from.
Pulse PSU's come with a superb 12cm fan that offers quiet operation but with proper cooling and airflow - less noise means you're working in a more peaceful environment and the right cooling ensures maximum lifespan of your products.
Supplied with all the appropriate cables Pulse provides maximum compatibility with popular CPU's and mainboards.
Specification
  • Product Description: PULSE 550W PSU, 120MM SILENT RED FAN, PFC, 2 X SATA, BLACK CASING, RETAIL BOX
  • Wattage: 550W
  • Size: ATX 12V
  • Input Range: 230Vac, 10A, 50-60Hz
  • Connections: 240 +4 PIN Main Connector x1 / CPU 4-PIN 12V Connector x1 / SATA Connector x2 / 4 PIN Molox Peripheral Connector x3 / Floppy Drive Connector x1
  • Additional Features: Power Factor Control (PFC), Silent with better ventilation
  • Warranty: 1 Year
Warranty
1 Year
Power Rating
550 Watt
Best Value Pulse 550W 120mm Silent Red Fan SATA PFC PSU Bundle deal on Best Value Pulse 550W 120mm Silent Red Fan SATA PFC PSU
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.62 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£34.33
saving £8.68
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£24.79
Customer reviews
Write a review for the Best Value Pulse 550W 120mm Silent Red Fan SATA PFC PSU here!
Good for the money
Reviewed by Anonymous Review Posted 14/02/2013
Be warned that there are only plugs for 2 sata drives, not 4 as stated in the specification. If you need more you can always use a molex to sata convertor.
  • Overall 4*
  • Ease of use 4*
  • Value for money 5*
Could be better
Reviewed by Ads. Review Posted 15/07/2013
This PSU is very quiet, but the problem for me is that the EATX12V cable is not long enough for cases with the PSU at the bottom. I had to extend the cable.
Also there are too many standard molex connectors and only two SATA style connectors, three would be better.
Provides a floppy drive power connector, no idea why these days.
  • Overall 3*
  • Ease of use 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Brand: Best Value
Price Range Inc VAT: 0 - 50
