BT.com
Wishlist
Best Value Pulse 550W 120mm Silent Red Fan SATA PFC PSU
Best Value Pulse 550W 120mm Silent...
£14.72
Hurry, only 2 left in stock!
£14.72
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Pulse Power Supplies - A new brand of PSU that ensures stability and value for money. Excellent value for money doesn't mean corners have been cut - every Pulse PSU comes certified RoHS compliant and with Power Factor Control - giving you a safe and stable foundation to build systems from.
Pulse PSU's come with a superb 12cm fan that offers quiet operation but with proper cooling and airflow - less noise means you're working in a more peaceful environment and the right cooling ensures maximum lifespan of your products.
Supplied with all the appropriate cables Pulse provides maximum compatibility with popular CPU's and mainboards.
Specification
  • Product Description: PULSE 550W PSU, 120MM SILENT RED FAN, PFC, 2 X SATA, BLACK CASING, RETAIL BOX
  • Wattage: 550W
  • Size: ATX 12V
  • Input Range: 230Vac, 10A, 50-60Hz
  • Connections: 240 +4 PIN Main Connector x1 / CPU 4-PIN 12V Connector x1 / SATA Connector x2 / 4 PIN Molox Peripheral Connector x3 / Floppy Drive Connector x1
  • Additional Features: Power Factor Control (PFC), Silent with better ventilation
  • Warranty: 1 Year
Warranty
1 Year
Power Rating
550 Watt
Best Value Pulse 550W 120mm Silent Red Fan SATA PFC...
£14.72
Save on this ideal PC Build kit!
Save £9.28
£34.31
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
4* Good for the money
Reviewed by Anonymous on 14/02/2013
Be warned that there are only plugs for 2 sata drives, not 4 as stated in the specification. If you need more you can always use a molex to sata convertor.
3* Could be better
Reviewed by Ads on 15/07/2013
This PSU is very quiet, but the problem for me is that the EATX12V cable is not long enough for cases with the PSU at the bottom. I had to extend the cable.
Also there are too many standard molex connectors and only two SATA style connectors, three would be better.
Provides a floppy drive power connector, no idea why these days.
Scroll to top
