BT.com
Wishlist
Best Value Pulse 500W 120mm Silent Red Fan SATA PFC PSU
Best Value Pulse 500W 120mm Silent...
£12.82
Hurry, only 3 left in stock!
£12.82
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Pulse Power Supplies - A new brand of PSU that ensures stability and value for money. Excellent value for money doesn't mean corners have been cut - every Pulse PSU comes certified RoHS compliant and with Power Factor Control - giving you a safe and stable foundation to build systems from.
Pulse PSU's come with a superb 12cm fan that offers quiet operation but with proper cooling and airflow - less noise means you're working in a more peaceful environment and the right cooling ensures maximum lifespan of your products.
Supplied with all the appropriate cables Pulse provides maximum compatibility with popular CPU's and mainboards.
Specification
  • Product Description: PULSE 500W PSU, 120MM SILENT RED FAN, PFC, 2 X SATA, BLACK CASING, RETAIL BOX
  • Wattage: 500W
  • Size: ATX 12V
  • Input Range: 230Vac, 10A, 50-60Hz
  • Connectors: 1 x 240 +4 PIN Main, 1 x CPU 4-PIN 12V, 2 X SATA, 3 x 4 PIN Molex Peripheral, 1 x Floppy Drive Connector
  • Additional Features: Power Factor Control (PFC), Silent with better ventilation
  • Warranty: 1 Year
Power Rating
500 Watt
Warranty
1 Year
Best Value Pulse 500W 120mm Silent Red Fan SATA PFC...
£12.82
Save on this ideal PC Build kit!
Save £9.39
£32.35
Other bundles
£12.82
Save on Intenso 32GB USB Drive
Save £1.48
£17.32
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
2* Disappointed
Reviewed by Chris on 31/07/2016
Although advertised as 500w, good luck running a GTX 970 for example. The specific amperage etx is not clearly shown. My PC now goes to a blank screen whenever I try to play decent graphics like I could before I had this PSU. This is essentially a downgrade and doesn't have the relevant power connections for most modern GPU's. I had to wire in a 6 and 8 pin myself. Don't waste your money like me, get a Corsair or better.
1* Same as the Alpine 500
Reviewed by Anonymous on 22/05/2014
ended up buying the this PSU for £1.00 more as the Alpine PSU was out off stock, realized both psu look identical the only difference is that the Pulse comes in a nice looking retail box which does not really matter to me really as i was fixing a PC for a friend.
Scroll to top
