BT.com
Wishlist
Best Value Pulse 500W 120mm Silent Red Fan SATA PFC PSU
Delivery
Standard Due date unavailable
Pulse Power Supplies - A new brand of PSU that ensures stability and value for money. Excellent value for money doesn't mean corners have been cut - every Pulse PSU comes certified RoHS compliant and with Power Factor Control - giving you a safe and stable foundation to build systems from.
Pulse PSU's come with a superb 12cm fan that offers quiet operation but with proper cooling and airflow - less noise means you're working in a more peaceful environment and the right cooling ensures maximum lifespan of your products.
Supplied with all the appropriate cables Pulse provides maximum compatibility with popular CPU's and mainboards.
Specification
  • Product Description: PULSE 500W PSU, 120MM SILENT RED FAN, PFC, 2 X SATA, BLACK CASING, RETAIL BOX
  • Wattage: 500W
  • Size: ATX 12V
  • Input Range: 230Vac, 10A, 50-60Hz
  • Connectors: 1 x 240 +4 PIN Main, 1 x CPU 4-PIN 12V, 2 X SATA, 3 x 4 PIN Molex Peripheral, 1 x Floppy Drive Connector
  • Additional Features: Power Factor Control (PFC), Silent with better ventilation
  • Warranty: 1 Year
Power Rating
500 Watt
Warranty
1 Year
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
2* Disappointed
Reviewed by Chris on 31/07/2016
Although advertised as 500w, good luck running a GTX 970 for example. The specific amperage etx is not clearly shown. My PC now goes to a blank screen whenever I try to play decent graphics like I could before I had this PSU. This is essentially a downgrade and doesn't have the relevant power connections for most modern GPU's. I had to wire in a 6 and 8 pin myself. Don't waste your money like me, get a Corsair or better.
1* Same as the Alpine 500
Reviewed by Anonymous on 22/05/2014
ended up buying the this PSU for £1.00 more as the Alpine PSU was out off stock, realized both psu look identical the only difference is that the Pulse comes in a nice looking retail box which does not really matter to me really as i was fixing a PC for a friend.
Scroll to top
