BT.com
Wishlist
Best Value Palit GeForce GTX 770 1085MHz 2GB GDDR5 PCI-E 3.0 HDMI OC
Delivery
Standard Due date unavailable
The Palit GeForce® GTX 770 OC Version provides up to 7% performance enhancement at DX11(Unigine Heaven v2.5 1920x1200 nonAA/4AF). Adopted with DrMOS and Copper Based, which can ensure the extreme overclocking performance and stability. With triple Fan thermal design, Palit GeForce® GTX 770 series offer gamers additional outstanding options to experience groundbreaking gaming performance.
To optimize the revolutionary features of GeForce Series, Palit has revealed the enhanced "ThunderMaster" overclocking tool that fully utilizes NVIDIA GPU Boost technology for intelligent monitoring of clock speed, ensuring that the GPU runs safely at its peak and the game is at its highest frame rate. Palit ThunderMaster allows you to drag the performance to its maximum score!
With a single GeForce GTX you can expand your PC games across three displays in full stereoscopic 3D for the ultimate "inside the game "experience . NVIDIA Surround also supports triple screen gaming with non-3D Vision monitors. Add in a fourth accessory display to get access to your email, web , or other applications while you game.
  • To optimize the revolutionary features of GeForce Series, Palit has revealed the enhanced "ThunderMaster" overclocking tool that fully utilizes NVIDIA GPU Boost technology for intelligent monitoring of clock speed, ensuring that the GPU runs safely at its peak and the game is at its highest frame rate. Palit ThunderMaster allows you to drag the performance to its maximum score!
  • With a single GeForce GTX you can expand your PC games across three displays in full stereoscopic 3D for the ultimate "inside the game "experience . NVIDIA Surround also supports triple screen gaming with non-3D Vision monitors. Add in a fourth accessory display to get access to your email, web , or other applications while you game.
  • A Triple Fan design offers triple the cooling performance, and combined with the 8CM-9CM-8CM Smart Fans, heat is effectively drawn away from hot spots.
  • Unique 6-Phase PWM design reduces max current load to stabilize the voltage level and improve overclockability.
  • The new JetStream design adding large size copper base directly adhered with GPU and more heatpipes; that can efficiently dissipate the heat from GPU and make 20% cooler.
  • Dynamically enables vertical sync based on your current frame rates for the smoothest gaming experience.
  • Dynamically maximizes clock speeds based on workload and allows enthusiast class controls such as temperature target and fan controls, extra over-voltage headroom and optimizations for water-cooling solutions. This allows greater customization and overclocking options and enables gamers to push performance to new levels.
  • Designed for the new PCI Express 3.0 bus architecture offering the highest data transfer speeds for the most bandwidth-hungry games and 3D applications, while maintaining backwards compatibility with existing PCI Express motherboards for the broadest support.
  • DirextX 11 GPU with Shader Model 5.0 support designed for ultra high performance in the new API's key graphics feature, GPU-accelerated tessellation.
  • GeForce GPU support for NVIDIA 3D Vision, bringing a fully immersive stereoscopic 3D experience to the PC. A combination of high-tech wireless glasses and advanced software, 3D Vision transforms hundreds of PC games into full stereoscopic 3D.
  • Industry leading NVIDIA SLI technology offers amazing performance scaling for the world's premier gaming solution.
  • Full support for NVIDIA PhysX technology, enabling a totally new class of physical gaming interaction for a more dynamic and realistic experience with GeForce.A Triple Fan design offers triple the cooling performance, and combined with the 8CM-9CM-8CM Smart Fans, heat is effectively drawn away from hot spots.
Graphics Processor Manufacturer
NVIDIA
Graphics Processor
NVIDIA GeForce GTX 770
PCI Express 3.0
Memory Size
2 GB
Digital Output
Digital Visual Interface (DVI), DisplayPort, High-Definition Multimedia Interface (HDMI)
Core Clock
1085 MHz
Scroll to top
