Click to visit BT.com
BT.com
Wishlist
Best Value Palit GeForce GTX 660 980MHz 2GB PCI-Express 3.0 HDMI OC
Quicklinx: 89NQWS00
Mfr#: NE5X66001049-1060F
The GeForce GTX 660 is built for fast and fluid 1080p gaming in the latest DirectX 11 and NVIDIA PhysX-enabled games. Packed with all the Kepler features found in the flagship GTX 680, GeForce GTX 660 delivers the ideal fusion of power, performance and affordability.
  • Palit Own Design GTX 660
  • Kepler Architecture
  • NVIDIA GPU boost
  • Better Overclocking Performance
  • 28nm - high performance and low power
  • Support for 4 concurrent displays
  • Better cooler design, lower acoustic level
  • NVIDIA GPU Boost
  • NVIDIA TXAA technology
  • NVIDIA FXAA technology
  • NVIDIA Adaptive Vertical Sync
  • NVIDIA Surround technology
  • Support for four concurrent displays
  • Microsoft DirectX11
  • NVIDIA PhysX technology
  • NVIDIA SLI Ready
  • NVIDIA 3D Vision Ready
  • NVIDIA CUDA technology
  • PCI Express 3.0 support
  • OpenGL 4 2 support
Minimum System Requirements
  • PCI Express-compliant motherboard with one dual-width x16 graphics slot
  • One 6-pin PCI Express supplementary power connectors
  • Minimum 450W or greater system power supply (with a minimum 12V current rating of 24A)
  • Supported Operating Systems: Windows 7, Windows Vista, Windows XP
  • PCB: 173mm(L) x 112mm(W)
  • Board: 196mm (L)
  • Cooler :2 slot
  • Bracket: 2 slot
  • HDMI/DisplayPort/Dual DVI
Graphics Processor Manufacturer
NVIDIA
Graphics Processor
NVIDIA GeForce GTX 660
PCI Express 3.0
Memory Size
2 GB
Digital Output
High-Definition Multimedia Interface (HDMI)
Core Clock
980 MHz
