BT.com
Wishlist
Best Value Palit GeForce GTX 650 Ti 928MHz 1GB PCI-Express 3.0 HDMI
Delivery
Standard Due date unavailable
  • Palit Own Design GTX 650 Ti
  • Kepler Architecture
  • 28nm - high performance and low power
  • PCI Express 3.0 support
  • Better cooler design, lower acoustic level
  • Great Hardware Components
  • High Efficiency PWM design with supper slow RDS(on) MOSFET
  • Solid Capacitors
  • High quality Ferrite Core Chokes
  • GeForce GTX 650 Ti
  • Proceessor Tenhnology: 28nm
  • Processor Cores: 768 cores
  • Memory: 1024 MB
  • Memory Interface: 128 bit
  • DRAM Type: GDDR5
  • Core Clock: 928MHz
  • Memory Clock: 2700MHz (DDR 5400MHz)
  • Memory Bandwidth: 86.4(GB/Sec)
  • Power Consumption: 100W
  • NVIDIA Kepler GPU Architecture
  • SMX
  • Microsoft DirectX 11 support
  • NVIDIA 3D Vision ready
  • NVIDIA Surround technology
  • NVIDIA FXAA technology
  • NVIDIA TXAA technology
  • NVIDIA Adaptive Vertical Sync
  • NVIDIA PhysX technology
  • NVIDIA CUDA technology with CUDA C/C++, DirectCompute, and OpenCL support
  • NVIDIA PureVideo HD technology
  • OpenGL 4 3 support
Graphics card require
  • PCI Express-compliant motherboard with one dual-width x16 graphics slot
  • One 6-pin PCI Express supplementary power connector
  • Minimum 400W or greater system power supply (with a minimum 12V current rating of 20A)
  • Supported Operating Systems: Windows 7, Windows Vista, Windows XP
Dimension
  • Board: 168mm (L) x 112mm (W)
  • PCB: 145mm(L) x 112mm(W)
  • Cooler :2 slot
  • Bracket: 2 slot
Graphics Processor Manufacturer
NVIDIA
Graphics Processor
NVIDIA GeForce GTX 650 Ti
PCI Express 3.0
Memory Size
1 GB
Digital Output
Digital Visual Interface (DVI), High-Definition Multimedia Interface (HDMI)
Core Clock
928 MHz
Resources
The following resources are available for the Best Value Palit GeForce GTX 650 Ti 928MHz 1GB PCI-Express 3.0 HDMI
Scroll to top
