Click to visit BT.com
BT.com
Wishlist
Best Value Midi-TowerCase +500W PSU (USB 2.0 + HD Audio)
3.0*
Quicklinx: 7VWVWS00
Mfr#: OEM-710
New Mid Tower chassis for system building meeting the latest thermal requirements for dual core cpu's
  • Front door opened quick release
  • Piano finish to lower part of front panel
  • 3 x 5.25" included 1 x Steathed DVD cover
  • USB 2.0 x 2 | HD Audio to front panel
  • Vented for dual core systems to side
  • Excellent heat dissipation capabilities
  • Riveted SECC metal frame
  • ABS Plastic Front panel
  • Removable side panel with grips for easy removal and maintenance
  • Side Panels with filter for best ventilation
  • Expansion Slots 7
  • For Standard ATX and Micro ATX boards
  • Dimensions W172; D 410mm; H 400mm
  • ROHS Compliant
Specification
  • Audio Output: Y - HD Audio
  • I/O Ports: 2 x USB 2.0
  • Colour: Black
  • Weight: 5000g
  • Form Factor: Midi-tower
  • Supported Motherboard Form Factor: ATX / Micro ATX
  • Type: PC
  • Material: 0.5mm SECC
  • Ventilation Fans: External Drive bays: 3 x 5.25 / Internal Drive bays : 6 x 3.5 HDD
Case Form Factor
Mid tower
ATX/MicroATX
Power Supply
500 Watt
Customer reviews
Write a review for the Best Value Midi-TowerCase +500W PSU (USB 2.0 + HD Audio) here!
Midi tower case+500w PSU
Reviewed by Anonymous Review Posted 11/11/2013
The case is very good and easy to add all the components I fitted. However when I fired up and loaded Ubuntu it kept on shutting down and a window said the PSU was unstable, I had to fit another PSU
G W
  • Overall 4*
  • Ease of use 5*
  • Value for money 4*
Is this the same Case
Reviewed by Brian Gillard. Review Posted 20/06/2013
I can't believe this is the same case as review by others.
The case is well made, without sharp edges, and comes with sufficient fixings for ATX Motherboard, 3.5" hard disk, CD Disk, and comes with Speaker for M/B.The power supply has 2 SATA, 2 Molex, 1 floppy, 24pin and 4pin Motherboard power connector,and although it is not the quietest PSU it is not particularly noisy.The only complaint is the panel which covers the CD Drive has a button which missed the eject button on my Samsung Bluray disk.
To sum up I have found it to be a very good value case
  • Overall 4*
  • Ease of use 5*
  • Value for money 5*
PSU is junk, may as well sell it bare
Reviewed by Iain Hamilton. Review Posted 08/01/2012
The case itself isn't too bad considering the price but I cannot express strongly enough the need to purchase a PSU or have one ready to replace the unit that comes with this.
The PSU has no seperate connection for PCIe power and has only 1 SATA power connector making it pretty much useless for most new boards and peripherals.
  • Overall 3*
  • Ease of use 3*
  • Value for money 3*
Do not buy this case
Reviewed by Simon. Review Posted 15/03/2013
Yes its cheap but still expect a case that is not out of shape. You would have a more sturdy case if you used a Mcdonalds Brown bag.
These cases should not even be sold as PC cases
DO NOT BUY
  • Overall 1*
  • Ease of use 2*
  • Value for money 2*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
