BT.com
Wishlist
Best Value GeForce GTX 660 Ti 915MHz 2GB PCI-Express 3.0 HDMI
Delivery
Standard Due date unavailable
Palit GeForce GTX 660 Ti
  • Palit Own Design GTX 660Ti
  • 2 slot cooler
  • Kepler Architecture
  • DrMOS : Better Power Efficiency
  • Better Overclocking Performance
  • 3 Way SLI ready
  • 28nm - high performance and low power
  • Support for 4 concurrent displays
  • Better cooler design, lower acoustic level
  • NVIDIA GPU Boost
  • NVIDIA Adaptive Vertical Sync
  • NVIDIA Surround
  • Support for four concurrent displays
  • NVIDIA DirectX 11 with DirectCompute 5.0 support
  • NVIDIA PhysX technology
  • NVIDIA 3 Way-SLI Ready
  • NVIDIA 3D Vision Surround Ready
  • NVIDIA CUDA technology
  • PCI Express 3.0 support
  • OpenGL 4 2 support
  • OpenCL support
Graphics card require
  • PCI Express-compliant motherboard with one dual-width x16 graphics slot
  • Two 6-pin PCI Express supplementary power connectors
  • Minimum 450W or greater system power supply (with a minimum 12V current rating of 24A)
  • Supported Operating Systems: Windows 7, Windows Vista, Windows XP
PCB: 247mm(L) x 112mm(W) Cooler :2 slot Bracket: 2 slot
Resources
The following resources are available for the Best Value GeForce GTX 660 Ti 915MHz 2GB PCI-Express 3.0 HDMI
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* 660ti
Reviewed by Joshua on 09/09/2013
The 660 ti is an extremely popular kepler gpu, it is basically a 670 with a reduced memory bus. Alone it will run most if not all modern games at 1920x1080 native resolution on high/ultra. It also scales phenomenally well in SLI mode, coming shockingly close to doubling in performance. This model features a cooler that isn't far removed from the reference cards that we are all too familiar with except appearing more matte.
Scroll to top
