BT.com
Wishlist
Best Value Compro Videomate U620F DVB-T USB2
Delivery
Standard Due date unavailable
Compro VideoMate U620F DVB-T Stick is a USB 2.0 interface digital terrestrial TV tuner stick, which provides H.264 and 1080i HDTV quality digital TV watching/recording on your desktop or laptop PC. Also, the VideoMate U620F support analog FM radio reception. Accompanied by Compro's Picture Purifying Technology, VideoMate U620F DVB-T Stick provides crystal clear pictures watching on your PC without opening the system case to install, and turns your computer into a home entertainment center by bringing digital TV viewing and personal digital video recording capabilities to your PC.
Bundled with Compro's exclusive ComproDTV 4 software, you can watch digital TV shows, play recorded files, timeshift live TV, channel surf, capture still frames, and S3 (standby)/ S4 (hibernation) mode power up scheduled recording; support Transport Stream recording and playing back let you record all the programs in the same stream then you can watch each of them when you are free; customize channel order and set my favorite channel list for more easy-to-use; Video Desktop to setup the live TV screen in wallpaper mode can let you use other applications directly from desktop. The advanced Picture in/out Picture allow you to watch live TV/playback video file at the same time, open up to 1 main and 3 sub live digital channel windows at once.
In addition, VideoMate U620F DVB-T stick provides the useful Gadget tool to watch live TV directly on your Win 7/Vista sidebar, check schedule and playback list. Also, the ComproDTV 4 can integrate the scheduling list from WMC for more easy-to-use scheduled recording control. With these powerful features, VideoMate U620F DVB-T Stick is undoubtedly your best mobile digital TV and audio choice.
Bundled Software
  • ComproDTV 4 - Digital TV watch/record and DAB/DAB+ listen/record
  • ComproFM 2 - Listen to analog FM radio and recording
Package Contents
  • VideoMate U620F DVB-T Stick
  • Installation CD: ComproDTV 4, device drivers and documentation
  • Start Up Guide
  • USB 2.0 extension cable
  • Analog FM antenna
  • CPU -1.7 GHz for TV Viewing
  • 2.6 GHz with SSE 2 for DVD recording
  • 3.0 GHz with SSE 2 for HDTV/TS and PIP/POP
  • Intel Core 2 Duo 2.2 GHz for H.264 viewing/recording
  • Memory: 512 MB (1.0GB recommend)
  • Available USB 2.0 port
  • Free disc space 150MB minimum
  • CD drive for software installation
  • Sound card or on-board sound chip
  • Graphics Card or on-board graphics supports DirectX 9.0
  • OS: Windows XP SP3, Vista SP1, Win 7 x86/x64
Resources
The following resources are available for the Best Value Compro Videomate U620F DVB-T USB2
Scroll to top
