Click to visit BT.com
BT.com
Wishlist
Best Value 777 T-BIRD-Blue Gaming Case (No PSU)
4.0*
Quicklinx: 7W6PWS00
Mfr#: OEM-777-T-BIRD-BLUE
777 T-Bird chassis: New Mid Tower chassis for system building meeting the latest thermal requirements for dual core cpu's
  • Front door opened quick release
  • 2 x 5.25"; 1 x 3.5"
  • USB 2.0 x 2 | HD Audio to front panel
  • Vented for dual core systems to side
  • Excellent heat dissipation capabilities
  • Riveted SECC metal frame
  • ABS Plastic Front panel
  • Removable side panel with grips for easy removal and maintenance
  • Side Panels with Mesh filter for best ventilation
  • Thumbs screws for easy removal
  • Expansion Slots 7
  • For Standard ATX and Micro ATX boards
  • Dimensions W174; D 420mm; H 400mm
  • ROHS Compliant
Specification
  • Audio Output: Y - HD Audio
  • I/O Ports: 2 x USB 2.0
  • Colour: Black
  • Weight: 5000g
  • Form Factor: Midi-tower
  • Supported Motherboard Form Factor: ATX / Micro ATX
  • Type: PC
  • Material: 0.5mm SECC
  • Ventilation Fans: External Drive bays: 2 x 5.25 / Internal Drive bays : 1 x 3.5 | 6 x 3.5"
Case Form Factor
Mid tower
ATX/MicroATX
Power Supply
None
Blue
Customer reviews
Write a review for the Best Value 777 T-BIRD-Blue Gaming Case (No PSU) here!
Reviewed by grumpygit. Review Posted 27/11/2012
just received this case and on first impressions its a bargin.
front drive door has a little button on top to release the door and it opens on its own(spring loaded) with a nice smooth action to reveal two 5.25 and a 3.5 blanking plate between the 5.25.
inside its more run of the mill standard hdd mounting inline. but thats a minor gripe for a all in price of £20...
if your after a cheap basic matx/atx case that looks better than the price suggests have a look at one of these..
  • Overall 4*
  • Ease of use 3*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
