BT.com
Wishlist
Best Value 32" Bauer TV with HDMI and PVR
Sale - Was 198.67 !
Delivery
Standard Due date unavailable
The Bauer 32" TV features LED Backlighting to deliver brighter, crisper pictures for your viewing enjoyment. It includes an integrated Freeview tuner and great connectivity options - making it ideal for any room.This TV features LED back lighting to deliver a brighter, clearer picture quality. LED TVs create greater contrast ratios - making blacks appear blacker - leading to a sharper image. In addition, they also consume less power than similarly- sized LCD and Plasma TVs and are mercury free.
An integrated Freeview tuner will allow you to watch all your favorite shows from over 50 TV and 24 radio stations across the country - without the need for an additional set-top box. All you need to do is simply plug your TV into an aerial and scan for channels. You'll also have access to `red button' interactive services such as extra sporting coverage from the BBC and teletext, as well as accessibility features such as subtitling and Audio Description. A Slim LED style to this TV gives a more stylish look than the bulky LCD style. There are even TV's that are LED that also can have that unattractive bulky side to the TV. However this Bauer TV will really add to the look of your latest tech products with the slimmer style frame.
PVR Record is available through the use of a USB memory device (Sold separately) and the USB slot can also be used for viewing photos , playing music and playing many videos (dependent of file type) Being HD Ready, this TV will display crisp HD entertainment when connected to an HD source such as a games console or DVD Player when connected via an HDMI or component cable (sold separately).
Two HDMI inputs ensure you'll have enough ports to allow you to connect a couple of AV sources to your TV such as a home cinema system, games console, Blu-ray player/set-top box or a laptop. You'll also be able to switch between sources in an instant via your remote.
Fancy having your new TV up on your wall? This TV can be wall mounted very easily. Check out its VESA wall mount classification in the specification for its specific measurements or simply choose one of the two types of wall bracket we have for this sized TV. We stock either a tilting option which will allow you to move the TV up and down on the wall to adjust to different viewing positions, or a fixed bracket
For those who like to get fully immersed in the action or tend to watch TV or play games late in the evening there is a handy headphone port for you to connect any standard headphones to; saving you from disturbing the rest of the room. If you want to connect your laptop to your TV in order to watch a movie, surf the web in style or showcase a presentation for work, you can easily use this TV as your PC/laptop monitor. Either connect your laptop via the VGA or HDMI port on the TV and sit back and enjoy your media on the big screen.
LED
Diagonal Size (inches)
32 in
HD Standard
720p
Aspect Ratio
16:9
Freeview Bult In
Freeview
Component, Composite, HDMI, SCART, VGA, USB
Memory Card Reader / USB Ports Qty
1
HDMI Inputs
2
Television / HDMI Ports Qty
2
Contrast Ratio
3000:1
Miscellaneous / Features
PVR Via USB
Remote Control / Type
Remote control
Television / PC Interface
VGA (HD-15)
Television / HDTV Ready
TV Tuner / Teletext
Scroll to top
