BT.com
Wishlist
BenQ XL2735 Zowie 27" 2560x1440 1ms USB DP HDMI DVI-D LED Gaming
BenQ XL2735 Zowie 27" 2560x1440 1ms...
£661.15
18 in stock
£661.15
Add to wishlist
Delivery
Standard 1-3 working days
XL-series features the premiere monitors for PC e-Sports, fine-tuned to guarantee the smoothest and responsive experience, and the clearest images to arm you for competition.
Zowie XL Series XL2735 - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
65 kWh
Power Consumption (On mode)
45 W
USB Hub
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
2560 x 1440? at 144 Hz
Pixel Pitch
0.2335 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Input Connectors
2xHDMI, DVI-D, DisplayPort
Display Position Adjustments
63.3 cm x 22.6 cm x 55.9 cm
8.3 kg
Display Type
Energy Class
Class C
65 kWh
45 W
Diagonal Size
27"
Built-in Devices
USB Hub
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.2335 mm
Brightness
250 cd/m²
Contrast Ratio
Response Time
1 ms (grey-to-grey)
Backlight Technology
LED backlight
Black eQualizer, Low Blue Light Mode, Flicker Free technology, e-Sports, Shield
63.3 cm x 22.6 cm x 55.9 cm - with stand
8.3 kg
2 x HDMI , DisplayPort , DVI-D (dual link) , Headphones , Microphone , USB upstream , 3 x USB downstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
140 mm
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot
Protective cover, S Switch remote control
MTBF
60,000 hour(s)
30 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 63.3 cm - depth: 6.4 cm - height: 37.4 cm , With stand - width: 63.3 cm - depth: 22.6 cm - height: 55.9 cm - weight: 8.3 kg
Scroll to top
