BT.com
Wishlist
BenQ XL2730 Zowie 27" 2560x1440 2ms USB DP HDMI DVI-D LED Gaming
BenQ XL2730 Zowie 27" 2560x1440 2ms...
£542.48
£542.48
Add to wishlist
Delivery
Standard 1-3 working days
BenQ Zowie's XL-series features the premiere e-Sports monitors for PC competitors, fine-tuned to guarantee the smoothest and responsive experience, and the clearest images to arm you for competition.
Zowie XL Series XL2730 - 3D LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
60 kWh
Power Consumption (On mode)
41 W
3D Capable
USB Hub
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
2560 x 1440 at 144 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Grey, red
63.3 cm x 22.6 cm x 55.7 cm
7.5 kg
Environmental Standards
ENERGY STAR Qualified
TUV Bauart, TCO Displays 6.0
2 years warranty
Display Type
Energy Class
Class B
60 kWh
41 W
Diagonal Size
27"
3D Capable
Built-in Devices
USB Hub
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
HDCP, game mode, Black eQualizer, Low Blue Light Mode, Flicker Free technology, Motion Blur Reduction, K Locker, e-Sports
Grey, red
63.3 cm x 22.6 cm x 55.7 cm - with stand
7.5 kg
2 x HDMI (HDCP) , VGA (HD-15) , DisplayPort , DVI-D (dual link) , Headphones , Microphone , USB upstream , 3 x USB downstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
140 mm
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot
S Switch remote control
AC 90 - 264 V
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - depth: 6.1 cm - height: 33.5 cm , With stand - width: 63.3 cm - depth: 22.6 cm - height: 55.7 cm - weight: 7.5 kg
ENERGY STAR Certified
5 °C
20 - 90%
Other bundles
BenQ XL2730 Zowie 27" 2560x1440 2ms USB DP HDMI DVI-D...
£542.48
Save on TP Link Smart Plug
Save £2.00
£566.45
Scroll to top
