BT.com
Wishlist
BenQ XL2720 Zowie 27" 1920x1080 2ms USB DP HDMI DVI-D LED Gaming
BenQ XL2720 Zowie 27" 1920x1080 2ms...
£420.97
£420.97
Add to wishlist
Delivery
Standard 1-3 working days
Enjoy this premiere monitor for PC competitors, fine-tuned to deliver the smooth and responsive experience, and the clear images to arm you for competition.
Zowie XL Series XL2720 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
50 kWh
Power Consumption (On mode)
34 W
USB Hub
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 144 Hz
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Input Connectors
2xHDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
64.2 cm x 27.3 cm x 54.8 cm
7.5 kg
Display Type
Energy Class
Class B
50 kWh
34 W
Diagonal Size
27"
Built-in Devices
USB Hub
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Response Time
1 ms (grey-to-grey)
Backlight Technology
LED backlight
Game mode, Black eQualizer, Low Blue Light Mode, Flicker Free technology, Motion Blur Reduction, K Locker, e-Sports
64.2 cm x 27.3 cm x 54.8 cm - with stand
7.5 kg
2 x HDMI (HDCP) , VGA (HD-15) , DisplayPort , DVI-D (dual link) , Headphones , USB upstream , 3 x USB downstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
140 mm
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot
S Switch remote control
AC 90 - 264 V
50 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 64.2 cm - depth: 26.9 cm - height: 48.5 cm
Scroll to top
