BT.com
Wishlist
BenQ XL2540 Zowie 25"1920x1080 1ms USB DP HDMI DVI-D LED Gaming
BenQ XL2540 Zowie 25"1920x1080 1ms...
£498.76
14 in stock
£498.76
Add to wishlist
Delivery
Standard 1-3 working days
XL features the premiere monitors for PC e-Sports, fine-tuned to deliver the smooth and responsive experience, and the clear images to arm you for competition.
Zowie XL Series XL2540 - LED monitor - Full HD (1080p) - 24.5"
LED-backlit LCD monitor - 24.5"
Energy Class
Class B
Energy Consumption per Year
49 kWh
Power Consumption (On mode)
33 W
USB 3.0 hub
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
400 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DVI-D, DisplayPort
Display Position Adjustments
Black, red
51.543 cm x 22.604 cm x 56.994 cm
7.5 kg
2 years warranty
Display Type
Energy Class
Class B
49 kWh
33 W
Diagonal Size
24.5"
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Brightness
400 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
24 - 240 Hz
Horizontal Refresh Rate
15 - 160 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Black eQualizer, Low Blue Light Mode, Flicker Free technology, Shield
Black, red
51.543 cm x 22.604 cm x 56.994 cm - with stand
7.5 kg
2 x HDMI , DisplayPort , DVI-D (dual link) , 2 x USB 3.0 downstream , USB 3.0 upstream , Headphones , Microphone
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
140 mm
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot
Protective cover, S Switch remote control
1 x DisplayPort cable , 1 x USB cable
AC 90 - 264 V (47 - 63 Hz)
55 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
Limited warranty - 2 years - pick-up and return
5 °C
20 - 90%
Scroll to top
