BT.com
Wishlist
BenQ XL2430T 24" 1920x1080 2ms DVI HDMI DisplayPort LED Monitor
Delivery
Standard Due date unavailable
The next-generation gaming monitor, the XL24303, is a full package of gaming-focused solutions tailored to bring out the best in every gamer. Built with perfect motion, fast gaming, precise control, intuitive experience and gaming eye care, the 24" battle machine is at the peak of design perfection.
BenQ XL2430T - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
46 kWh
Power Consumption (On mode)
32 W
USB 3.0 hub
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
350 cd/m²
Contrast Ratio
12000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Black / red
56.8 cm x 19.9 cm x 52 cm
7 kg
Environmental Standards
ENERGY STAR Qualified
TUV Bauart, TCO Displays 6.0
2 years warranty
Display Type
Energy Class
Class B
46 kWh
32 W
Diagonal Size
24"
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
24 - 144 Hz
Horizontal Refresh Rate
15 - 140 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, sharpness, input select, colour temperature, phase
Carrying handle, HDCP, Auto Brightness Control, Advanced Motion Accelerator (AMA) technology, 72% NTSC colour gamut, Senseye 3 Technology, game mode, Black eQualizer, Smart Scaling, NVIDIA 3D LightBoost technology, integrated cable management, FPS Mode, Low Blue Light Mode, Flicker Free technology, RTS Mode, Motion Blur Reduction, Display Pilot
Black / red
56.8 cm x 19.9 cm x 52 cm - with stand
7 kg
2 x HDMI (HDCP) , VGA (HD-15) , DisplayPort , DVI-D (dual link) , Headphone/microphone combo jack , 2 x USB 3.0 downstream , USB 3.0 upstream , Management (USB)
Mechanical
Tilt Angle
-5/+20
Swivel Angle
45
Rotation Angle
90
Height Adjustment
140 mm
Flat Panel Mount Interface
100 x 100 mm
Protective cover, S Switch remote control
1 x USB cable , 1 x DVI cable
Power Supply
Internal
AC 120/230 V (47 - 63 Hz)
23.2 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Included Software
Drivers & Utilities, Display Pilot
Microsoft Windows 7, Windows 8, Windows 8.1
Dimensions & Weight Details
Without stand - width: 56.8 cm - depth: 6.1 cm - height: 33.5 cm
Limited warranty - 2 years - pick-up and return
5 °C
20 - 90%
Accessories
£7.69
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£22.29
£42.00
£57.43
Scroll to top
