BT.com
Wishlist
BenQ XL2430 Zowie 24" 1920x1080 2ms HDMI DVI-D LED Gaming Monitor
BenQ XL2430 Zowie 24" 1920x1080 2ms...
£386.48
£386.48
Add to wishlist
Delivery
Standard 1-3 working days
The next-generation gaming monitor, the XL2430T, is a full package of gaming-focused solutions tailored to bring out the best in every gamer. Built with perfect motion, fast gaming, precise control, intuitive experience and gaming eye care, the 24" battle machine is at the peak of design perfection.
Zowie XL Series XL2430 - 3D LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
46 kWh
Power Consumption (On mode)
32 W
3D Capable
USB 3.0 hub
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 144 Hz
Pixel Pitch
0.276 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Black, red
56.8 cm x 19.9 cm x 52 cm
7 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class B
46 kWh
32 W
Diagonal Size
24"
3D Capable
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
72% NTSC colour gamut, Senseye 3 Technology, game mode, Black eQualizer, Low Blue Light Mode, Flicker Free technology, Motion Blur Reduction, K Locker, e-Sports
Black, red
56.8 cm x 19.9 cm x 52 cm - with stand
7 kg
2 x HDMI , VGA (HD-15) , DisplayPort , DVI-D (dual link) , 3 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
140 mm
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot
Protective cover, S Switch remote control
50 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 56.8 cm - depth: 6.1 cm - height: 33.5 cm , With stand - width: 56.8 cm - depth: 19.9 cm - height: 52 cm - weight: 7 kg
ENERGY STAR Certified
Other bundles
BenQ XL2430 Zowie 24" 1920x1080 2ms HDMI DVI-D LED...
£386.48
Save on TP Link Smart Plug
Save £2.00
£410.45
Scroll to top
