BT.com
Wishlist
BenQ XL2411Z 24" 1920x1080 2ms DVI-D HDMI Speakers LED Gaming Monitor
Delivery
Standard Due date unavailable
A gaming monitor that gives you no excuse to lose - the 24-inch XL2411Z brings an unprecedented level of control and fluidity with perfect motion to help you conquer any enemy in FPS gaming. The BenQ monitor is built with the Motion Blur Reduction technology, low blue light, Gaming-comfort Flicker-free, Gaming Refresh rate Optimization Management (GROM), and display pilot feature, offering agile performance, viewing comfort and convenience in one package! With the XL2411Z, you'll be up for any challenge coming your way!
BenQ XL2411Z - 3D LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class C
Energy Consumption per Year
52 kWh
Power Consumption (On mode)
36 W
3D Capable
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Black / red
57 cm x 22.2 cm x 43.1 cm
6 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
TUV Bauart, TCO Displays 6.0
Display Type
Energy Class
Class C
52 kWh
36 W
Diagonal Size
24"
3D Capable
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
24 - 144 Hz
Horizontal Refresh Rate
15 - 140 kHz
Video Bandwidth
330 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
HDCP, Advanced Motion Accelerator (AMA) technology, 72% NTSC colour gamut, Senseye 3 Technology, nVidia 3D Vision 2 Ready, Low Blue Light Mode
Black / red
6 kg
VGA , DVI-D (dual link) (HDCP) , HDMI , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), Flicker-free technology
1 x DVI cable , 1 x VGA cable
Power Supply
Internal
AC 120/230 V
22 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Included Software
Display Pilot
ENERGY STAR Certified
Accessories
£7.34
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£20.13
£39.66
£53.73
Scroll to top
