BT.com
Wishlist
BenQ XL2411 Zowie 24" 1920x1080 2ms HDMI DVI-D LED Gaming Monitor
BenQ XL2411 Zowie 24" 1920x1080 2ms...
£278.19
Hurry, only 1 left in stock!
£278.19
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Monday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
BenQ ZOWIE's XL-series features the premiere e-Sports monitors for PC competitors, fine-tuned to guarantee the smoothest and responsive experience, and the clearest images to arm you for competition.
Zowie XL Series XL2411 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class C
Energy Consumption per Year
52 kWh
Power Consumption (On mode)
36 W
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 144 Hz
Pixel Pitch
0.276 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
57 cm x 22.2 cm x 43.1 cm
5.9 kg
Display Type
Energy Class
Class C
52 kWh
36 W
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
350 cd/m²
Contrast Ratio
Response Time
1 ms (grey-to-grey)
Backlight Technology
LED backlight
Game mode, Black eQualizer, Low Blue Light Mode, Flicker Free technology, e-Sports
57 cm x 22.2 cm x 43.1 cm - with stand
5.9 kg
HDMI , VGA (HD-15) , DVI-D (dual link) , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot
Stand
AC 120/230 V
45 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 57 cm - depth: 6.3 cm - height: 34.7 cm
Other bundles
BenQ XL2411 Zowie 24" 1920x1080 2ms HDMI DVI-D LED...
£278.19
Save on TP Link Smart Plug
Save £2.00
£302.16
Scroll to top
