BT.com
Wishlist
BenQ VZ2770H 27" 1920 x 1080 4ms HDMI VGA LED Monitor
BenQ VZ2770H 27" 1920 x 1080 4ms...
£193.23
£193.23
Add to wishlist
Delivery
Standard 1-3 working days
The BenQ V70 series with the narrow bezel chic design, delivers rich and exquisite visual performance that please your eyes. A pure expression of broad viewing from inside out.
BenQ Stylish V70 Series VZ2770H - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
51 kWh
Power Consumption (On mode)
35 W
Panel Type
A-MVA+
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
61.4 cm x 21.184 cm x 46.116 cm
5.3 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class B
51 kWh
35 W
Diagonal Size
27"
Panel Type
A-MVA+
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Backlight Technology
LED backlight
Colour Temperature
9300K, 6500K, 5700K
72% NTSC colour gamut, Slim Design, Low Blue Light Mode, Flicker Free technology, ecoFACTS Label
5.3 kg
VGA , 2 x HDMI , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
1 x VGA cable - 1.5 m , 1 x HDMI cable - 1.5 m
Backlight Life
30,000 hours
MTBF
60,000 hour(s)
AC 90 - 264 V
27 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Microsoft Windows 7 / 8 / 8.1
Other bundles
BenQ VZ2770H 27
£193.23
Save on TP Link Smart Plug
Save £2.00
£217.20
Accessories
C2G 2M HD15 M/M UXGA MONITOR CBL W/ FE
Quicklinx: 63P0 | In Stock
£9.03
£9.46
£11.42
£9.04
£11.82
C2G VGA to Composite PC-TV Video Adapter
Quicklinx: 7CC5 | In Stock
£40.32
Scroll to top
