BT.com
Wishlist
BenQ RL2755 Zowie 27" 1920x1080 1ms DVI-D HDMI LED Gaming Monitor
BenQ RL2755 Zowie 27" 1920x1080 1ms...
£264.28
Hurry, only 1 left in stock!
£264.28
Add to wishlist
Delivery
Standard 1-3 working days
Every detail of the RL-series is designed and fine-tuned for the exceptional console e-Sports experience. The ZOWIE RL-series has been adopted worldwide by most professional e-Sports tournaments and players. With your persistence and dedication to win backed by the exclusive features of the RL-series, you will be armed to compete in FPS, fighting or sports games on any console.
Zowie RL Series RL2755 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
47 kWh
Power Consumption (On mode)
32 W
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Input Connectors
2xHDMI, DVI-D, VGA
Display Position Adjustments
Tilt
63.9 cm x 21.4 cm x 47.8 cm
5.5 kg
Display Type
Energy Class
Class B
47 kWh
32 W
Diagonal Size
27"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Response Time
1 ms (grey-to-grey)
Backlight Technology
LED backlight
Game mode, Black eQualizer, FPS Mode, Low Blue Light Mode, Flicker Free technology, e-Sports, Lag-free technology, FTG Mode
63.9 cm x 21.4 cm x 47.8 cm - with stand
5.5 kg
Audio
Speakers
Output Power / Channel
2 Watt
2 x HDMI , VGA (HD-15) , DVI-D (dual link) , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot
Stand
AC 120/230 V
45 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 63.9 cm - depth: 5.9 cm - height: 37.8 cm
Scroll to top
