BT.com
Wishlist
BenQ RL2460 Zowie 24" 1920x1080 1ms HDMI DVI-D LED Gaming Monitor
BenQ RL2460 Zowie 24" 1920x1080 1ms...
£198.60
£198.60
Add to wishlist
Delivery
Standard Due date unavailable
Every detail of the RL2460 is designed and fine-tuned for the exceptional console e-Sports experience. The ZOWIE RL-series has been adopted worldwide by most professional e-Sports tournaments and players. With your persistence and dedication to win backed by the exclusive features of the RL-series, you will be armed to compete in FPS, fighting or sports games on any console.
The RL2460 exclusively lets you set up a head-to-head combat station without being disturbed by your opponents.
Zowie RL Series RL2460 - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
40 kWh
Power Consumption (On mode)
27 W
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Input Connectors
3xHDMI, DVI-D, VGA
Display Position Adjustments
57.9 cm x 21.3 cm x 50.2 cm
5.2 kg
Display Type
Energy Class
Class B
40 kWh
27 W
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Response Time
1 ms (grey-to-grey)
Backlight Technology
LED backlight
Game mode, Black eQualizer, FPS Mode, Low Blue Light Mode, Flicker Free technology, e-Sports, Lag-free technology, FTG Mode, Head-to-head Combat Setup
57.9 cm x 21.3 cm x 50.2 cm - with stand
5.2 kg
Audio
Speakers
Output Power / Channel
2 Watt
3 x HDMI , VGA (HD-15) , DVI-D (dual link) , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot
AC 120/230 V
45 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 57.9 cm - depth: 6.3 cm - height: 35 cm
Scroll to top
