BT.com
Wishlist
BenQ RL2455HM 24" 1920x1080 1ms HDMI DVI VGA LED Monitor with speakers
Delivery
Standard Due date unavailable
The RL2455HM is a professional gaming monitor suited for RTS game play. This 24" W LED monitor is packed with the features: the black eQualizer, height adjustment Stand, RTS mode, display mode, smart scaling, 1 ms GTG, HDMI and 12M: 1 dynamic contrast ratio. Poor visibility in dark scenes can cost even the most skillful gamers their game. The black eQualizer color engine technology is designed to offer an unprecedented level of control and visibility. Dark scenes are brightened without over-exposing the bright areas to preserve vital details, enabling gamers to spot their enemies easily in critical combat and react quickly in any situation.
BenQ RL2455HM - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
39 kWh
Power Consumption (On mode)
27 W
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
5 ms (typical); 1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Swivel, tilt
Black / red
57.9 cm x 18.9 cm x 43.5 cm
4.1 kg
Environmental Standards
ENERGY STAR Qualified
TCO Displays 5.2
Display Type
Energy Class
Class B
39 kWh
27 W
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
HDCP, 72% colour gamut, Advanced Motion Accelerator (AMA) technology, Senseye 3 Technology, Black eQualizer, Smart Scaling
Black / red
57.9 cm x 18.9 cm x 43.5 cm - with stand
4.1 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
DVI-D (dual link) , 2 x HDMI , VGA , Headphones , Audio line-in
Mechanical
Swivel, tilt
Tilt Angle
-5/+15
Flat Panel Mount Interface
100 x 100 mm
Wall mountable, K-lock security slot
TCO Displays 5.2
Power Supply
Internal
AC 120/230 V
27 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
Microsoft Windows 7, Windows 8
Dimensions & Weight Details
Without stand - width: 57.9 cm - depth: 6.3 cm - height: 35 cm , With stand - width: 57.9 cm - depth: 18.9 cm - height: 43.5 cm - weight: 4.1 kg
Scroll to top
