Click to visit BT.com
BT.com
Wishlist
BenQ MS502 SVGA (800 x 600) DLP Projector 2700 ANSI lumens
Quicklinx: 8G73WS00
Mfr#: 9H.J6D77.13E
World-Leading SmartEco Technology
for a Greener Environment
Schools today face the challenge of introducing new technologies and teaching tools into their classrooms and cut down on energy costs. In the effort to help schools meet the learning needs of their students as well as the green goals set by the school district, BenQ has collaborated with Philips Lighting in developing the perfect solution – the SmartEco Technology.
The SmartEco Technology brings a new way of operating the projector lamp system. Intuitive to use and environmentally friendly, this technology brings together the finest picture quality and maximum energy saving. With the SmartEco Technology, students and teachers get to make the most out of their classroom experience – and schools reduce the total cost of ownership with extended lamp life and lowered maintenance needs.
Eco Blank Mode
The Eco Blank mode allows teachers to blank the projection screen whenever they need to direct their students’ focus back on them – or simply when the projector is not in use. When activated, this special feature dims the lamp power automatically, lowering the total power consumption by up to 70%.
Full Power On
100% Lamp Power
Attention on the Projection Screen
Eco Blank Mode On
30% Lamp Power at the Lowest
Attention on the Class Instructor
SmartEco Mode
The SmartEco mode is designed to use only the exact amount of lamp power a projector needs to deliver the best contrast performance. With this feature, schools get to provide students and teachers uncompromised projection quality and reduce the total cost of ownership by extending the lamp life and lowering power consumption.
Normal Mode
296W Projector Power Consumption by Average
SmartEco Mode
Enhanced Details in Darkened Scenes
163W Projector Power Consumption by Average
(Source: 2010 Philips white paper)
No Source Detected Mode
There will be times when a projector is turned on without a display source, such as a classroom PC or notebook. To avoid a projector from running with full lamp power, BenQ created the No Source Detected Mode to lower the projector lamp brightness to 30% after the projector has remained unconnected to a display source for more than three minutes.
Source Detected
100% Lamp Power
No Source Detected
30% Lamp Power
Long Lamp Life at up to 6500 hours
Enjoy a lamp life performance of up to 6500 hours* – twice the lamp life expectancy of average projector lamps on the market! This certainly lowers the number of lamp changes and keeps all maintenance to a minimum.
*Lamp life results will vary depending on environmental conditions and usage.
BrilliantColor™ Performance
The MS502 gives you the truest, liveliest color ever with advanced BrilliantColor™ technology from Texas Instruments, where mid-tone colors are boosted to heighten brightness levels, making images more precisely rendered than ever.
Orginal Color With Brillant Color (Simulated Photo)
Stereoscopic 3D Ready Projection
MS502 is equipped with 3D projection technology to bring you the same amazing 3D effects you get in 3D movies. Offered for no added cost, the 3D feature on 3D ready BenQ projectors get your audience for an immersive real-life experience. Go ready with 3D glasses, content and video card along with the MS502. A magical expedition is just to begin!
*Please click to know more details about 3D Support and Compatibility.
ecoFACTS Label
ecoFACTS can tell you how eco-friendly BenQ products are!
Development of eco-friendly products, BenQ doesn't just want to comply with green regulations passively, but also to actively develop eco-friendly products!
ecoFACTS declares BenQ's greatest efforts on the replacement of hazardous substances, material selection, packaging design, energy-saving design and other aspects of the products.
  • Arsenic-free optical glass
  • BFR/PVC-free casing plastics
  • PVC-free plastic packaging
BenQ MS502 DLP projector - 3D
DLP projector
3D Capable
Built-in Devices
Speaker
Brightness
2700 lumens
Contrast Ratio
13000:1
Resolution
SVGA (800 x 600)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
190 Watt
Bulb life cycle
Up to 4500 hour(s) / up to 6000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video ( NTSC, SECAM, PAL )
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Video Output
RGB
Speakers
Speaker(s) - integrated
Microsoft Certification
Compatible with Windows 7
AC 120/230 V ( 50/60 Hz )
275 Watt
28.7 cm x 23.2 cm x 11.4 cm
2.3 kg
DLP projector
3D Capable
Built-in Devices
Speaker
Projector
Brightness
2700 lumens
Contrast Ratio
13000:1
Image Size
101 cm - 762 cm
Throw Ratio
1.86 - 2.04:1
Resolution
SVGA - SVGA (800 x 600) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 102 kHz
Bulb type
190 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
Freeze frame, Closed Caption, wall colour correction, BrilliantColor, DLP 3D Ready, 3D Color Management, blank screen, ecoFACTS, SmartEco Technology
Lens
Lens Aperture
F/2.56-2.8
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, composite video, S-Video
Video Modes
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
Input Device
External
2 x component video / RGB input - 15 pin HD D-Sub (HD-15) ¦ 1 x S-video input - 4 PIN mini-DIN ¦ 1 x composite video input - RCA ¦ 1 x audio line-in - mini-phone stereo 3.5 mm ¦ 1 x VGA output - 15 pin HD D-Sub (HD-15) ¦ 1 x audio line-out - mini-phone stereo 3.5 mm ¦ 1 x serial RS-232 - 9 pin D-Sub (DB-9) ¦ 1 x USB - 4 PIN USB Type B
Wireless remote control
1 x VGA cable
Security Features
Password protection
Nominal Voltage
275 Watt
Power Consumption Operational (Standby)
0.5 Watt
Software Included
Drivers & Utilities
28.7 cm
23.2 cm
11.4 cm
2.3 kg
Sound Emission
33 dBA
26 dBA
