BT.com
Wishlist
BenQ GW2870H 28" 1920x1080 5ms VGA HDMI LED Monitor
Delivery
Standard Due date unavailable
The GW2870H VA LED monitor brings viewing pleasure to everyday work and play with great details on the exterior and striking visual performance delivered by high contrast ratio, wide viewing angle, dual HDMI and sleek design.
BenQ GW2870H - LED monitor - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class B
Energy Consumption per Year
49 kWh
Power Consumption (On mode)
34 W
Panel Type
VA
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.32 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Display Position Adjustments
Tilt
Black texture, glossy black
65.9 cm x 20.4 cm x 47.7 cm
5.5 kg
Environmental Standards
ENERGY STAR Qualified
TCO Displays 6.0
Display Type
Energy Class
Class B
49 kWh
34 W
Diagonal Size
28"
Panel Type
VA
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.32 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
HDCP, Advanced Motion Accelerator (AMA) technology, 72% NTSC colour gamut, Dynamic Power Saving (DPS), Low Blue Light Mode, Flicker Free technology, ecoFACTS Label, Advanced Frame Rate Control (AFRC), 8-bit gamma
65.9 cm x 20.4 cm x 47.7 cm - with stand
5.5 kg
VGA , 2 x HDMI , Headphones
Mechanical
Tilt
Tilt Angle
-5/+15
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot
1 x VGA cable , 1 x HDMI cable
TCO Displays 6.0
AC 120/230 V
27 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 65.9 cm - depth: 5.4 cm - height: 38.1 cm
Accessories
£7.20
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£20.25
£38.41
£52.03
£17.48
Scroll to top
