BT.com
Wishlist
BenQ GW2765HT 27" 2560x1440 8ms DVI HDMI DisplayPort IPS LED Monitor
Delivery
Standard Due date unavailable
The 27" BenQ GW2765HT QHD(WQHD) IPS monitor delivers the best view for home entertainment and the highest productivity for office work with the finest precision in each and every detail. With the eye-friendly Low Blue Light technology, this stunning display not only makes a perfect investment for your visual pleasure but also for your eye health.
BenQ GW2765HT - LCD monitor - 27"
LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
70 kWh
Power Consumption (On mode)
48 W
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
4 ms
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Height, swivel, tilt
64.1 cm x 22.4 cm x 55.5 cm
6.9 kg
Environmental Standards
ENERGY STAR Qualified
TCO '06
Display Type
LCD monitor / TFT active matrix
Energy Class
Class C
70 kWh
48 W
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Controls & Adjustments
Colour temperature
HDCP, Advanced Motion Accelerator (AMA) technology, Senseye 3 Technology, Flicker Free technology, Ultra-Flexible Height Adjustment System (HAS)
6.9 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
DVI-D , VGA , Headphones , HDMI , DisplayPort , Audio line-in
Mechanical
Flat Panel Mount Interface
Wall mountable, K-lock security slot
1 x VGA cable - 1.5 m , 1 x DisplayPort cable - 1.5 m , 1 x HDMI cable - 1.5 m
TCO '06
Power Supply
Internal
AC 90 - 264 V
32 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
Accessories
£7.58
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£21.64
£41.53
£56.29
Scroll to top
