BT.com
Wishlist
BenQ GW2450HM 24" 1920x1080 4ms VGA DVI-D HDMI LED Monitor
Delivery
Standard Due date unavailable
Built to bring you the ultimate personal visual entertainment, the BenQ GW2450HM is certainly one of a kind! Featuring the ultra-high 5000:1 native contrast, 20 M:1 dynamic contrast ratio, and true 8-bit panel performance with deep blacks and minimized light leakage, this VA LED monitor refreshes your view with truly fantastic colors and details. And, its HDMI connectivity leads the path to a whole level of multimedia enjoyment.
BenQ GW2450HM - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Stereo speakers
Panel Type
VA
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
5000:1 / 20000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Glossy black
57.9 cm x 17.9 cm x 43.7 cm
4.1 kg
Environmental Standards
ENERGY STAR Qualified
TUV, TCO Displays 5.2
2 years warranty
Display Type
Diagonal Size
24"
Built-in Devices
Stereo speakers
Panel Type
VA
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, colour temperature, phase
HDCP, Senseye 3 Technology
Glossy black
57.9 cm x 17.9 cm x 43.7 cm - with stand
4.1 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
Audio line-in , HDMI , DVI-D (HDCP) , VGA , Headphones
Mechanical
Tilt
Tilt Angle
-5/+15
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot
1 x VGA cable ¦ 1 x audio cable
Power Supply
Internal
AC 120/230 V (47 - 63 Hz)
22 Watt
Power Consumption Stand by
0.3 Watt
Included Software
Drivers & Utilities
Dimensions & Weight Details
With stand - width: 57.9 cm - depth: 17.9 cm - height: 43.7 cm - weight: 4.1 kg , Without stand - width: 57.9 cm - depth: 6.3 cm - height: 35.1 cm
ENERGY STAR Certified
Limited warranty - 2 years - pick-up and return
5 °C
20 - 90%
Scroll to top
