BT.com
Wishlist
BenQ GW2270HM 21.5" 1920x1080 5ms VGA DVI HDMI Monitor
BenQ GW2270HM 21.5" 1920x1080 5ms...
£107.66
10 in stock
£107.66
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Wednesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
The GW2270HM monitor with Eye-Care design brings viewing pleasure to work and play with exquisite details on striking visual performance.
BenQ GW series GW2270HM - LED monitor - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class A
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
20 W
Panel Type
A-MVA+
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
18 ms (tr - tf); 5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Textured black, glossy black
50.56 cm x 17.817 cm x 40.007 cm
3.6 kg
Environmental Standards
ENERGY STAR Qualified
TUV, TCO Displays 6.0
Display Type
Energy Class
Class A
29 kWh
20 W
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
A-MVA+
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, Eco-Mode, Advanced Motion Accelerator (AMA) technology, 72% NTSC colour gamut, Dynamic Power Saving (DPS), Low Blue Light Mode, Flicker Free technology, Colour Temperature Selection
50.56 cm x 17.817 cm x 40.007 cm - with stand
3.6 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
DVI , HDMI , VGA , Audio line-in
K-lock security slot
1 x VGA cable
Backlight Life
30,000 hours
MTBF
60,000 hour(s)
AC 120/230 V
26 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 50.56 cm - depth: 17.817 cm - height: 40.007 cm - weight: 3.6 kg , Without stand - width: 50.56 cm - depth: 5.05 cm - height: 30.42 cm
ENERGY STAR Certified
Scroll to top
