BT.com
Wishlist
BenQ GL2760H 27" 1920 x 1080 5ms LED HDMI Glossy Black
BenQ GL2760H 27" 1920 x 1080 5ms...
£154.58
More than 50 in stock
£154.58
Add to wishlist
Delivery
Standard 1-3 working days
Whether you are catching up on the show on the Internet or viewing documents, the BenQ GL2760H LED monitor is the perfect choice for you in style! Featuring dynamic ratio of 12M:1, Flicker-free, and response time of 2 ms, this 27" 16:9 LED monitor delivers you the audiovisual enjoyment.
BenQ GL2760H - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
45 kWh
Power Consumption (On mode)
31 W
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
2 ms (gray-to-gray)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Glossy black
64.1 cm x 21.5 cm x 48.8 cm
5.4 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class B
45 kWh
31 W
Diagonal Size
27"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
2 ms (gray-to-gray)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
HDCP, 72% NTSC colour gamut, Senseye 3 Technology, Flicker Free technology
Glossy black
5.4 kg
VGA , DVI , HDMI , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
Power Supply
Internal
AC 120/230 V
28 Watt
Power Consumption Stand by
0.3 Watt
On / Off Switch
No
ENERGY STAR Certified
Accessories
£8.55
£9.58
£16.21
C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL
Quicklinx: 63SL | In Stock
£9.58
£9.48
C2G USB to DVI Adapter Up To 2048 x 1152
Quicklinx: 8H1Y | In Stock
£46.38
C2G 2m HDMI to DVI-D Digital Video Cable
Quicklinx: 915T | In Stock
£8.10
£62.48
Scroll to top
