BT.com
Wishlist
BenQ GL2460HM 24" 1920 x 1080 5ms HDMI DVI VGA Monitor with speakers
BenQ GL2460HM 24" 1920 x 1080 5ms...
£143.95
£143.95
Add to wishlist
Delivery
Standard Due date unavailable
Whether you're catching up on the latest show on the Internet or viewing documents, the BenQ GL2460HM LED monitor is the perfect choice for you in style! Featuring Senseye Human Vision technology with optimized eco mode and reading mode, a dynamic ratio of 12M:1, and 2 ms GtG response time, this 24" 16:9 LED monitor delivers every image detail with the best viewing quality. And, its HDMI connectivity leads the path to a whole level of multimedia enjoyment.
BenQ GL2460HM - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
39 kWh
Power Consumption (On mode)
27 W
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
2 ms (gray-to-gray)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Glossy black
56.5 cm x 19.4 cm x 43.4 cm
4.3 kg
Environmental Standards
EPEAT Silver
TCO Displays 6.0
Display Type
Energy Class
Class B
39 kWh
27 W
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
2 ms (gray-to-gray)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
HDCP, Eco-Mode, Advanced Motion Accelerator (AMA) technology, Senseye Human Vision Technology, Senseye 3 Technology
Glossy black
56.5 cm x 19.4 cm x 43.4 cm - with stand
4.3 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI (HDCP) , HDMI , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
Wall mountable, K-lock security slot
TCO Displays 6.0
Power Supply
Internal
AC 120/230 V
23 Watt
Power Consumption Stand by
0.3 Watt
On / Off Switch
No
Microsoft Windows 7, Windows 8
Dimensions & Weight Details
Without stand - width: 56.5 cm - depth: 5.4 cm - height: 3.33 cm
EPEAT Compliant
EPEAT Silver
Scroll to top
