BT.com
Wishlist
BenQ GL2460 24" 1920 x 1080 5m DVI-D Thin Bezel Monitor
Clearance
Last Few Remaining
Price Drop
Price Drop!
Delivery
Standard 1-3 working days
Whether you're catching up on the latest show on the Internet or viewing documents, the BenQ GL2460 LED monitor is the perfect choice for you in style! Featuring Senseye Human Vision technology with optimized eco mode and reading mode, a dynamic ratio of 12M:1, and 2 ms GtG response time, this 24" W 16:9 LED monitor delivers every image detail with the best viewing quality.
BenQ GL2460 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
2 ms (gray-to-gray)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Glossy black
56.5 cm x 19.4 cm x 43.4 cm
4.3 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
TCO Displays 6.0
Display Type
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
2 ms (gray-to-gray)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
Eco-Mode, 72% colour gamut, Advanced Motion Accelerator (AMA) technology, Senseye Human Vision Technology, Senseye 3 Technology
Glossy black
56.5 cm x 19.4 cm x 43.4 cm - with stand
4.3 kg
VGA , DVI-D
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot
TCO Displays 6.0
Power Supply
Internal
AC 120/230 V
23 Watt
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Accessories
£8.25
£9.21
£16.21
C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL
Quicklinx: 63SL | In Stock
£9.21
£9.48
C2G USB to DVI Adapter Up To 2048 x 1152
Quicklinx: 8H1Y | In Stock
£43.99
C2G 2m HDMI to DVI-D Digital Video Cable
Quicklinx: 915T | In Stock
£8.10
£59.29
Scroll to top
