BT.com
Wishlist
BenQ GL2450TC 24" 1920x1080 5ms DVI HDMI Glossy Black Monitor
Delivery
Standard Due date unavailable
Whether you're catching up on the latest show on the Internet or viewing documents, the BenQ GL2450 LED monitor is the perfect choice for you in style! Featuring a dynamic ratio of 12M:1, Senseye Human Vision technology, 5ms response time and DVI connector, this 24" W 16:9 LED monitor delivers every image detail with the best viewing quality.
BenQ GL2450TC - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
39 kWh
Power Consumption (On mode)
27 W
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
2 ms (gray-to-gray)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Height, pivot (rotation), tilt
57.9 cm x 21.3 cm x 50.2 cm
5.1 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, ISO 9241-307, TCO Displays 5.2
2 years warranty
Display Type
Energy Class
Class B
39 kWh
27 W
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
2 ms (gray-to-gray)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
HDCP, Senseye 3 Technology
5.1 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI-D , HDMI , Headphones , Microphone
Mechanical
Tilt Angle
-5/+15
Rotation Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot
1 x VGA cable
AC 90 - 264 V (47 - 63 Hz)
On / Off Switch
No
Limited warranty - 2 years - pick-up and return
5 °C
10 - 90%
Accessories
£8.24
£9.21
£16.21
C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL
Quicklinx: 63SL | In Stock
£9.21
£9.48
C2G USB to DVI Adapter Up To 2048 x 1152
Quicklinx: 8H1Y | In Stock
£43.93
C2G 2m HDMI to DVI-D Digital Video Cable
Quicklinx: 915T | In Stock
£8.10
£59.19
Scroll to top
