BT.com
Wishlist
BenQ GL2450HT 24" 1920x1080 5ms HDMI DVI-D LED Monitor
Delivery
Standard Due date unavailable
Build with an LED backlight panel, 16:9 100% dot-to-dot image quality, high adjustment stand and BenQ's exclusive Senseye technology to offer you the best viewing quality at all times. With the GL2450HT LED monitor, things are certainly looking great!
BenQ GL2450HT - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
39 kWh
Power Consumption (On mode)
27 W
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
5 ms (tr - tf); 2 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Glossy black
57.9 cm x 21.3 cm x 50.2 cm
5.1 kg
Environmental Standards
ENERGY STAR Qualified
TCO Displays 5.2
Display Type
Energy Class
Class B
39 kWh
27 W
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
HDCP, 72% colour gamut, Advanced Motion Accelerator (AMA) technology, Senseye Human Vision Technology, Senseye 3 Technology
Glossy black
57.9 cm x 21.3 cm x 50.2 cm - with stand
5.1 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
DVI-D (HDCP) , HDMI , VGA , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+15
Swivel Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot
TCO Displays 5.2
Power Supply
Internal
AC 120/230 V
23 Watt
Power Consumption Stand by
0.3 Watt
On / Off Switch
No
ENERGY STAR Certified
Scroll to top
